Looking on Craigslist in ND - looks like most of the driving jobs are Belly & Dump, Oil, Sand and Water,
can someone run through the particulars of what these jobs entail? pros and cons?
I have been running dry van and reefer - never done oil field work
Thanks
Discussion in 'Oilfield Trucking Forum' started by gojack, Aug 19, 2013.
And general difference in pay for each?
OK, who are the major players? Best choice(s)?
(...question was pros/cons of Belly & Dump, Oil, Sand and Water...not Craigslist) -
Do some research online. If you spend some time researching you'll come up with 30 or 40 trucking outfits in North Dakota. If you do even more research you'll find them all over the place....Texas, Wyoming, Montana, Colorado, Kansas, Oklahoma, Pennsylvania, West Virginia, California, New Mexico. If you spend the time to call these places you will find a handful of outfits that are worth working for. Currently there are several outfits in North Dakota that have trucks with sleepers. There you go, there is your house. I won't tell you what outfits do this, you'll have to do the research. Good luck! Also, if you've never worked in the oil fields you should be prepared. Mud- knee deep.....cold, cold wind..... white-outs.....and some more mud. After three years hauling sand, water, and crude, I have found that pulling a belly dump is more to my liking. It pays less, but you can still make 70-80k if you work for the right company and get 80 or so hours a week. It's an easy job cause you get to stay in the cab. Sometimes you have to chain up but that's not a big deal, you do that when you go OTR.
Belly dump:
1. Long days
2. Easy as hell
3. Gonna run heavy so have some hp
4. Have an xm radio
5. Can get rained out
6. Great money
7. Gotta be mobile if you wanna get called. -
1) Sand, 12 loads a week and you're making a nice check. Ups and downs and sometimes hard to get those loads. Lots of blacktop. Easy.
2) Water, many loads a day. Lots of dirt roads, or, exclusively dirt roads. You're in and out of the truck working. Good money.
3) Crude, between those two. Great money. Need to know what "buying oil" is and whether you want to do that.
Don't know much about belly dump.
