belly dump vrs. end dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by TexasHauler, May 18, 2012.
  1. TexasHauler
    TexasHauler Bobtail Member
    paradise tx
    Getting ready to start a new trucking business what would y'all buy a end or belly dump
  3. malrob
    malrob Bobtail Member
    mt holly nj
    rear unload with piping to use as a center drop
  4. RockinChair
    RockinChair Road Train Member
    5,060
    12,725
    Feb 19, 2012
    CC, TX
    Depends on what kind of jobs you'll be doing. Ask your customers which one they need more.
  5. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    End dump with door chains.:biggrin_25514:
    Less problems less parts and more uses.
    It beats getting a ladder and crawling in the belly dump to get a big rock out that jammed belly dump door that will not close. That is a really pane in the but.:biggrin_25513:
  6. Plinker
    Plinker Light Load Member
    91
    44
    May 4, 2012
    Eastern NC
    I used to run a hopper bottom if that's what's you meant by belly dump and rear dump. Used to run a little of fertilizer on the rear dump and more animal feed ingredients on the belly dump. I found the belly dump to be less of a hassle. I didn't have to mess with hydraulic lines, fluid, leaks or the PTO going out. the biggest help I found of bell dump/hopper bottoms were vibrators. When the load would hang up all you had to do was turn them on. I didn't have to climb up with the shove(or whatever else) and try to loosen it up.
