Bendix AD9 rebuild
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Jan 23, 2010.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    I am going to do some maintenance on my Bendix AD9 air dryer, cartridge=pretty straight foward. The check valve only 2 choices after I determine thread size.
    On the purge valve, hard seat kit and soft seat kit difference is the first is just the purge valve rebuild kit in existing housing and second purge valve is already in a new or reman housing with heater just install a couple of Orings and bolt it in???
    Would you use aftermarket brand for this if so which?
    thanks again,,,,,,,,
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    In my opinion it is better to just replace the whole unit with a reman. By the time you tear one apart and rebuild it you really aren't saving any money. It has to come off the truck anyway, I would just replace the whole thing.
  4. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
  5. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    try to get one that is remanned by bendix
  6. gafred99
    155
    12
    May 28, 2009
    Tignall
    I replaced my Bendix AD9 wirh a SKF remaned air dryer. Almost 2 months latter it build no pressure and keeps blowing air out the purge valves exhaust port.
    Of course no warranty on the unit, replace the purge valve???
  7. Heavyd
    7,751
    6,184
    Feb 4, 2009
    No, replace with a Reman Bendix AD9 like we all said.
