Bendix TF550 boost leak at inlet
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allan5oh, May 15, 2016.
  1. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    The fitting where the air comes in is leaking between it and the head. My detoit makes up to 45 lbs of boost. This sucker was off only maybe a couple years ago and has been leaking for a while. What are my options here?
    - Run silicon instead of the obviously crappy gasket?
    - Lap the surfaces?
    - Run a bigger compressor (TF750) but run the inlet off atmosphere instead?
    - Turn down the engine?
    It's a PITA because I have to take the compressor out and that makes me cranky! The inlet is well hidden on the back side. It's leaking REALLY bad. Could be a cracked head even it's that bad. From 20 PSI it leaks down to nothing within 2 seconds.
  3. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Looking online you can upgrade to the BA-922 as it's designed NOT to be used with a turbo. But it doesn't sound like a straight swap.
  4. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Good thing I was stubborn, turns out it was just the hose. But air does leak through the compressor. Will charging the system make a difference? I'm not sure it will. I bet air is getting by the rings which is to be expected.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If you're pressure testing the intake system, then sure, a little will get passed the rings, but shouldn't be much. If the air system is empty, then it will push air through the compressor until the tank pressure is equal.
    Cetane+ Thanks this.
  6. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I swear I hear some going past an intake valve too. Rockers are off.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Well that could be a problem. I'd plug the hose going to the compressor and check again just to eliminate it as a suspect. Any air seeping past the compressor rings goes in the crank case. You could hear an air leak into the crank case all around the head with the valve cover off.
  8. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    So just to be clear I have to plug the line to eliminate air going past the rings on the compressor? It's always exposed to intake air no matter what? That just seems goofy to me because it will leak boost into the crank case when it is not compressing.
    I'll get a better measurement as to how much the compressor is leaking, plug it, and try the other way. The leak I previously fixed is many multiples larger though. We're talking 20 psi to 0 in 3 seconds.
    I see your point there though, air going past the compressor could show up in other areas throwing me for a loop.
  9. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I also tested the duralite cac and it held 30 psi for 30 minutes without moving the needle.
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    If your air tanks are drained and the compressor inlet in plugged (the line from the intake manifold to the compressor), then the compressor has no air pressure in it to leak by the rings. If you do that and no longer hear what you thought was an intake valve leaking, then it's the compressor and not a real issue, a little seepage is normal. If you still hear it, then you need to keep hunting.
    Also, most Detroits leak at the intake gaskets a tiny bit, spray some soapy water around the intake manifold gaskets under pressure. I have seen that a lot, even brand new. When I install them, I use high tack spray on the head, manifold and both sides of the gaskets and let it dry good, then stick it together. I've never seen it cause an issue, it's so small, but that might be a noise you're hearing too.
  11. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Compressor fitting plugged in manifold and it still slowly leaks to about 10 psi. It does not leak at the manifold gasket and is leaking enough that I would notice. I definitely hear it by the intake valves but cannot isolate if its coming through the seals or by the valves itself. It's impossible to isolate even with a mechanics stethoscope. All seem to be doing it an equal amount so it wouldn't surprise me if this was normal.
    I'm still thinking about doing something about the compressor. I'd imagine once it's warm the amount of loss decreases quite a lot.
    I also found a bolt missing from my governor!
