Best 2000+ Pure sine inverter at This time
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, May 10, 2020.
  1. Transportacion R&R
    Transportacion R&R Light Load Member
    175
    73
    Apr 10, 2020
    Can you guys send me a few links with the best Pure Sine inverters out there at this time running at least 2000W. Thanks in advance
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
  4. Tb0n3
    Tb0n3 Road Train Member
    4,695
    9,482
    Oct 5, 2012
    Earth
    Just be sure to verify the dimensions for where you want it. They can be quite long. I got my AIMS from theinverterstore.com and it was pretty good, at a price. It did pop a blade fuse on the inside at some point (kind of difficult to get to). Not using it anymore due to the new truck having an Eaton inverter installed with wall plugs. That, I can say with certainty, is a revolution in convenience.
  5. abyliks
    abyliks Road Train Member
    4,027
    9,480
    May 2, 2010
    ludlow MA
    my last 3000 aims popped after 4 months of use, have a 3000 watt Duracell now and it can barely keep up with my microwave, I’d like to find a better one
  6. Tb0n3
    4,695
    9,482
    Oct 5, 2012
    Earth
    Did you open up the AIMS to check the fuses? They're standard automotive blade types.
  7. abyliks
    4,027
    9,480
    May 2, 2010
    ludlow MA
    yea one of the caps or whatever internally blew there was shmeg all over it
  8. Tb0n3
    4,695
    9,482
    Oct 5, 2012
    Earth
    Well ####. That's sucks. They're kind of the only option for workable units under $1000 it seems.
  9. Ridgeline
    22,640
    120,686
    Did you by chance contact AIMS?
  10. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Maybe your battery cables to your inverter are to small are you running at least a 2 gauge cable ?
  11. Antinomian
    Antinomian Road Train Member
    2,142
    3,396
    Feb 17, 2013
    A 2 gauge? For a 3kw inverter?
    I would think it needs a 4/0 gauge, or maybe a 3/0 gauge if the run is short.
    86scotty, HoneyBadger67 and Roberts450 Thank this.
