Best Antenna for Ford F 150
Discussion in 'CB Radio Forum' started by rcaldw, Oct 25, 2018.
  1. rcaldw
    rcaldw Bobtail Member
    4
    Have a Bearcat 980 SSB. Right now have a firestik firefly (4') mounted on the front of the bed next to the cab. SWR below 1.5 on both 1 and 40. But I hear these people crystal clear from miles away and I wonder what I'm missing? My radio is stock. Do these folks buy these super powered cb's? Is there a better antenna for me to use on my Ford?
  3. buddyd157
    buddyd157 Road Train Member
    13,547
    34,716
    May 25, 2017
    under a shade tree
    if you can hear them...CRYSTAL CLEAR, then you are all set....
    rcaldw Thanks this.
  4. Stinky Dairy Air
    Stinky Dairy Air Light Load Member
    124
    220
    Apr 18, 2014
    Midwest
    It sounds like it's as good as it gets. Let it ride & enjoy.
    rcaldw Thanks this.
  5. rcaldw
    4
    Yeah, I really can't much of the time unless they are close. That's why I was wondering about the antenna.
    a. What's the best one for a truck like mine
    b. Would moving it back toward the end of the truck help out?
  6. Stinky Dairy Air
    124
    220
    Apr 18, 2014
    Midwest
    I wouldn't run out and buy an antenna if the one you have is working fine but I would stick with the whip antennas.
    Up on the roof would be the best position but moving it further down the bed of the truck won't make any difference.
    rcaldw Thanks this.
  7. buddyd157
    13,547
    34,716
    May 25, 2017
    under a shade tree
    you have your antenna mounted the same way i had mine, and i too had a very low SWR reading.....leave it alone. if anything at all, maybe a 5 footer, instead of the 4..???
    do not forget, cb radios have a rather short range, unless you have the right atmospheric conditions to get out further.
    rcaldw Thanks this.
  8. BigJim63
    BigJim63 Light Load Member
    58
    56
    May 1, 2014
    Evansville In.
    The receiver on the 980 is very good. You will probably hear transmissions that are farther away.
    rcaldw Thanks this.
  9. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,209
    Oct 25, 2015
    Fort Worth
    1). Disconnect the antenna. Hold it high.
    2). Have friend drive Ram underneath.
    3). Re-connect.
    Now you’re good.
  10. Stinky Dairy Air
    124
    220
    Apr 18, 2014
    Midwest
    So that's what I've been doing wrong the last 11 years? I need to trade this International for a Ram.
  11. buddyd157
    13,547
    34,716
    May 25, 2017
    under a shade tree
    until about 3 to 5 years, and the RAM rots out. like they usually do. then replace with a Ford or GM....
    tucker Thanks this.
