Best APU To Buy That Does It All ?
Discussion in 'Ask An Owner Operator' started by OONewbie, Apr 1, 2015.
  1. OONewbie
    OONewbie Light Load Member
    245
    134
    Dec 2, 2014
    Charlotte,NC
    Looking for a all in one APU that does cooling,heat & power and has to be quiet not loud as a reefer unit ... with enough wattage to run a tv/computer/microwave and cookware/coffee maker "Of coarse not all @ once. but has enough continuance power to handle the load of any of those components.
    I was looking at the TriPac for a step installation ? RigMaster or any other good ones out there ? Which is the most reputable,reliable and does it all?
    Looking for a solid reliable unit that will need little maintenance as possible. suggestions?
    If you can post links where to buy one or dealer location? etc...
    Thanks all, be safe out there & keep them wheels turning
    Chinatown Thanks this.
  3. Aggravated Owner
    Aggravated Owner Light Load Member
    87
    67
    Aug 19, 2014
    Sounds like you need a generator big enough to run a full sized hospital. :thumbright:
    I'm sure some sound advice is coming your way.
    OONewbie and Chinatown Thank this.
  4. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    OONewbie Thanks this.
  5. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Could always go the home brew route.
    harbor freight predator generator
    shore power inverter charger
    roof mount ac
    plug in heater
  6. dannythetrucker
    2,856
    4,032
    May 26, 2011
    everywhere, man
    that's what I've been doing the last two years. I recommend Honda EU3000is gen. it isn't the cheapest but for quiet, long life, dependability it's worth it IMO. you really can't beat a roofmount AC either, hang meat in there. quartz heaters work great, plug in block, good to go in winter. but now I'm getting a new truck and just don't quite want to cut a hole in the roof.
    double yellow, OONewbie and Chinatown Thank this.
  7. Chinatown
    Chinatown Road Train Member
    75,564
    172,907
    Aug 28, 2011
    Henderson, NV & Orient
    apu-center.com might find a good deal on a new or used one.
    There's also apucenter.com but the website doesn't show where they're located. Offer new or used. Area code shows they're in Missouri.
  8. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    Where's your sense of adventure?
  9. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Tripac is quiet, dependable, and you can get service all over the country.
  10. dannythetrucker
    2,856
    4,032
    May 26, 2011
    everywhere, man
    technically it's 72% my banker's truck, and he has 0% sense of adventure.
  11. icsheeple
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    I've seen rooftop AC's mounted on Double Bunk Classics going down the road, but haven't seen one up close yet. I haven't even research the max angle you can mount one. For now I have a little fan and a miserable look on my face. It's going to be a scorcher.
    My buddy has a little plug in AC and says he likes it. I'll check it out when I get my generator mounted.
    Charli Girl Thanks this.
