Best CB radio
Discussion in 'CB Radio Forum' started by shellhart, Feb 11, 2013.
  1. shellhart
    shellhart Light Load Member
    78
    10
    Apr 6, 2010
    memphis tn
    I know this is abig personal prefferance however what does everyone think is the best cb to get. Only thing is I only want to use the factory power. I dont want to run a thicker power wire
  3. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    The good ole Cobra 29 LTD Classic is good one.
  4. EZ Money
    EZ Money Road Train Member
    You can go up to about 30 to 40 watts using the trucks wiring.
    Most standard Cobra 29 LTD will tune to about 25 to 30 watts as well as many other brands.
    You may need to use just a little higher rated fuse on the CB power cord.
    So many choices on radios but the Cobra 29 has been around forever.
    A good tech doing the peak and tune on a 29 will give you a good sounding radio.
  5. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,528
    Jan 19, 2008
    Berea, KY
  6. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    The "best CB" is a loaded question. Also depends on what you need it to do.
    For the typical OTR trucker that plans to run on 19 and doesn't need sungle side band, I personally recommend the Cobra 25 radios as well as the Uniden PC 66/68 radios....as these radios give you everything you need in one package w/o a bumch of useless stuff.
    The 29's are better if you want to add an echo board or want to add a few noise toys as they have a little more room, but not much. A Uniden PC 76/78 is about the same as the 29.
    Either way a 25, 29 or a 66/68 or 78 all give you the same amount of performance. I prefer the Uniden radios as they are typically cheaper than the Cobras plus they still use their own boards.
    Also the best Cobras were the ones built by Dynascan with Uniden boards in them.
  7. kor b
    kor b Light Load Member
    254
    103
    Dec 16, 2008
    When starting out with this cb stuff, i suggest
    planning for a system that can grow. A cobra
    25 or a Uniden 66 is ideal. At first you need nothing
    special as far as direct power to the battery.
    don't let anyone do a super tune or any name they
    use that takes out the modulation limiter. Build a
    system in the beginning that focusses on the antenna,
    coax, mounting. Then when, not if your ready for more
    power you have the basics covered.
  8. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    X2 on the antenna system. Run a one piece coax to a stainless mount and stud and the tallest antenna that will fit. But not a Wilson fiberglass one. I had one that lasted 3 months before it shorted out.
    Voltrucker Thanks this.
  9. dougs5300
    dougs5300 Bobtail Member
    32
    9
    Jun 19, 2011
    Toledo, Ohio
    I have a Galaxy 929 from Custom cb radios that has the best rx of any Ive tried.
  10. shellhart
    78
    10
    Apr 6, 2010
    memphis tn
    Yeah im mpt new to the cb. I have a 29 with all the bells and whistles except a rfx kit. I have had it for years abnd love it. I was just thinking about getting something bigger. But from the sound of it i need to just keepol trusty lol
  11. Voltrucker
    467
    133
    Sep 24, 2012
    West TN
    Don't get the "super tune"! This mod is nothing but a problem causer! Causes nothing but distorted audio and decreases the life of your finals. Just get a basic peak and tune! Run a Astatic 636 or a Road King 56. The new Road King's are made by a different company now and they don't sound as well as when Turner made them. Run a Wilson 2000 trucker series antenna. I recommend buying the radio and getting the work done by Chuck at the I-40 Exit 126 CB Shop in Tennessee. He's a OUTSTANDING tech and is VERY reasonable! Call him at 731-847-9296. His hours are M-F 8-5 and Saturday 8-12 CST.
