Best Engine
Discussion in 'Questions From New Drivers' started by Hellbringer, Oct 28, 2007.
only one vote per subject
  1. *
    Longest living (miles on engine) - Caterpillar
    42.9%
  2. *
    Longest living (miles on engine) - Detroit
    26.5%
  3. *
    Longest living (miles on engine) - Cummins
    20.4%
  4. *
    Best MPG - Caterpillar
    14.3%
  5. *
    Best MPG - Detroit
    53.1%
  6. *
    Best MPG - Cummins
    18.4%
  7. *
    Lowest cost to rebuild - Caterpillar
    6.1%
  8. *
    Lowest cost to rebuild - Detroit
    46.9%
  9. *
    Lowest cost to rebuild - Cummins
    32.7%
  10. *
    Coolest Sounding - Caterpillar
    59.2%
  11. *
    Coolest Sounding - Detroit
    14.3%
  12. *
    Coolest Sounding - Cummins
    22.4%
  13. Lowest Maintenance cost - Caterpillar
    14.3%
  14. *
    Lowest Maintenance cost - Detroit
    53.1%
  15. *
    Lowest Maintenance cost - Cummins
    24.5%
  1. Hellbringer
    Hellbringer Bobtail Member
    15
    Los Angeles
    hi i am woundering what you guys thin about these engines and whic one is the best in the different subjects
    mike
  3. MACK E-6
    49,016
    227,540
    Hey, you forgot Mack engines, such as the model after which I named myself.
    I think they are the longest living, coolest sounding, and have the lowest costs. Or should I say, had the lowest costs...
    I think fuel economy has to go to Detroit though.
  4. Etosha
    Etosha World Citizen
    745
    50
    Aug 19, 2007
    Edmonton, AB
    Boy can I confirm this statement... seems to just go and go after every time I fuel!
  5. Hellbringer
    15
    Los Angeles
    yeah i realized after i posted the poll that i forgot mack and international and i dont see how it can be updated
    mike
  6. capnhector
    capnhector Light Load Member
    you would have to repost and have a mod close this one.
  7. Hellbringer
    15
    Los Angeles
    its ok just if you want to vote mack or international just post iy
    thanks mike
  8. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    Excuse me while I :biggrin_25523: :biggrin_25523: :biggrin_25523: :biggrin_25523: at the idea that a Diptroit will last longer in terms of miles than a CAT or a Cummins.
    Please pass what ever it is you are taking. I need some too. :biggrin_25523: :biggrin_25523:
    Bean Jr. Thanks this.
  9. Johnny99
    Johnny99 Johnny be Good
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    Those old Macks were like the Energizer Bunny, the just kept going and going and going.................and some of the old transmissions were bulletproof.
  10. Truckerjo
    Truckerjo Road Train Member
    2,314
    341
    Sep 5, 2006
    Indiana
    I always say Mack has made the best truck over the CB and usually get hassled... Mack to me is the best truck ever built and its a shame you see little of them on the road... You go where tough trucks are needed such as mining ext.. you will definitely see a Mack....
    Fuel mileage well it would be a toss up between Detroit and a Cummins.. I lean towards the cummins when it comes to fuel mileage...(listed engines)
    Maintenance no doubt should go to Detroit
    Cat if maintained correctly defiantly outlast other listed engines...
  11. Colotow
    Colotow Bobtail Member
    23
    8
    Dec 22, 2007
    CSC Scania, Iraq
    brand don't have much to do with it, it's the driver and maintainence. a well maintained detroit will outlast a beaten on cat
    i run wreckers, so my answer is based on what i've driven and what i've towed in and why
    cat- heavy, hard on fuel, hideously expensive to repair. one piece head, likes to lose head gaskets, and injector tips. will trash the whole head. big hp AND torque. will run about forever if taken care of, i work with an O/O that bought his pete new (86) and has over 3mil on it (3 inframes)
    cummins. my personal favorite (460/525 split hp N14) excellent power, smooth, pulls good, got decent mileage if i didn't run at 2100 rpm all day. older ones, like N14's, had 3 heads, only replace the one damaged. will lose injectors, but no engine damage. strong jakes. forgiving when beaten on. will break jake springs if revved too high on jakes, but easy fix.
    detroit ser 60 smallest engine. light, best fuel MPG. has the hp on paper, but nowhere's near the torque, usually 1400-1500 lbft, cat and cummins will normally be around 1650-1850 lbft. most likely to break a rod if over revved, lose injectors, blow turbos. most common engine on the road, so also the most likely to be towed in. i pulled 6 series 60's for every 3 cats and 1 cummins if it was an engine problem.
    cat and cummins both sound good, i like cummins jakes better.
