Best Exhaust for W900 w/acert
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat nip, Jul 12, 2010.
  1. Cat nip
    Cat nip Light Load Member
    192
    10
    Jan 17, 2010
    Magnolia, TX
    I am looking for highflow mufflers for a w900. I know about the pittsburgh power but I was reading on their website that they are loud. I run teams with my wife so I don't wanna be waking her up! Any suggestions would be greatly appreciated...
  3. Cat nip
    192
    10
    Jan 17, 2010
    Magnolia, TX
    None of you W9 guys have tried any hi-flow mufflers?
  4. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I have a W900 but its a day cab so the mufflers go up the side. I run megaflows from NAPA they are not very loud but if you have an aerocab that is usless info to you.
  5. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    All of the high flow mufflers for the W900L Aerocab are about the same. Because it is that one goofy single muffler under the bunk you don't have a lot of options. Performance Diesel Inc. in St George, Ut also has a high flow muffler but it's almost exactly the same as the Pittsburgh Power one.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    you can mount 2 of the pitts mufflers under in series and it will be as quit as you like. i mounted mine on the fuel tank brackets (one on each side) and ran 180 degree pipes to connect.
  7. grizzly
    599
    432
    Aug 27, 2008
    Layton, Ut
    Could you please post pictures of that? How much did that cost? I know the mufflers are about $150 each.
  8. Cat nip
    192
    10
    Jan 17, 2010
    Magnolia, TX
    Mine has 2 mufflers under the cab. if you have a louder muffler under the cab the noise will be there right? Rumbling the sleeper? That's what Pitts. P.'s website said. If I just turn it into straights, and delete the mufflers will it be rattling the sleeper or just loud coming out of the pipes?
  9. Hanadarko
    Hanadarko Independent Owner/Operator
    2,970
    934
    Oct 1, 2009
    Midwest
    Couldnt you run straights with internal resonators in the stacks?
    Would that work?
  10. Cat nip
    192
    10
    Jan 17, 2010
    Magnolia, TX
    Dunno, do they flow pretty good???
  11. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    I pulled the two crappy stock cat style from under my 2004 W900, went back with two of the stock Walkers that are found on the older W9s; (most have just one). Quieter, but they are expensive, around $200/per IIRC, and still have that roaring sound. My truck doesn't have an insulation package, and am adding neoprene sponge under the floor. Not nearly finished, but noticing a big difference already.
