best for the engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hellpatrol, Jan 9, 2017.
  1. hellpatrol
    hellpatrol Light Load Member
    221
    172
    Apr 22, 2013
    In general, which would be better for the engine, hold the boost steady or the RPM? I hear that holding the rpm is best for fuel mileage and I also hear that about the boost. The most important thing to me is which is the best for the engine, then which is better fuel savings-wise.
  3. Brandt
    Brandt Road Train Member
    4,506
    6,168
    Sep 17, 2012
    Operating the engine in it's sweet spot will get your your best MPG and that would be the best thing for the engine. Things like letting the engine cool 3-5 minutes after running is good.
    hellpatrol Thanks this.
  4. Steel Tiger
    Steel Tiger Road Train Member
    2,665
    3,221
    Jun 6, 2012
    Orlando, FL
    The boost and RPM work the same. Lower the RPM, lower the boost. Higher RPM, higher boost.
    You need to find the engine's sweet spot; the place that gets you the most MPG at cruising speed. It will vary from engine make to engine make.
    The faster you go, the higher the RPM and boost, obviously. Most newer engines such as the Detroit DD-15 well have a sweet spot of anywhere from 55 MPH to 65 mph, typically in the 1200-1300 RPM range. A lot will be determined by the rear axle's ratio. The higher the number, the slower you will have to go in order to maximize fuel economy.
    It'll take some trial and error to figure that out tho. A huge help would be if you have a display that shows your current MPG while driving and you can adjust accordingly.
    Another option is to have a 3rd party device, such as a Scan Gauge to help you see your engine stats.
    Don't be too hasty in determining your results in a 100 mile stretch. There are numerous variables that will affect the results: wind, weight, terrain, etc.
    Just because you got 1 result for a small stretch doesn't necessarily mean that's your sweet spot. Trying to determine the sweet spot for your individual truck takes time....at least 1 month of varying speeds over varied trial terrain and weather conditions.
  5. hellpatrol
    221
    172
    Apr 22, 2013
    I do have the ability to see the mpg and my boost and, of course , the rpm. It seemed that iit's around 1,300 rpm that I get about 10 #'s of boost in almost all gears. This seems to yield to best results, but I was just thinking of climbing hills. I tried 1,500 and the engine worked great, but the fuel economy suffered. Try keeping it at 10 #'s and the truck slows to a ridiculous crawl where I just give up because I'm eventually going to stop. 20 #'s usually gets the job done, 30 if I have to.
  6. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    The least amount of boost will give the best economy. Until you start climbing a hill. When on hill you are almost full or full throttle and going slow. Pay no attention to the instant read out. Here's an example if you pull that hill super slow with low boost and low rpms it may read better on your instant read out but you're on the hill longer. Down shift get your rpms up to max boost and your instant read out will show using more fuel but you will have a shorter burn time. Make sense?
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    You will get the best fuel economy with the lowest average boost psi. When climbing a hill you have to pick a place between keeping boost very low or full power. I always found keeping it under 10 psi when open road and letting the speed vary a little bit combined with hill climbs keeping it 20 or 25 psi while climbing worked the best. You don't get to the top of the hill very much faster by hammering it all the way up.
  8. hellpatrol
    221
    172
    Apr 22, 2013
    Thanks guys. I kinda found that out these last couple days. Each hill is different and I'm always a different weight, but I try and keep the boost below 25 if I can. I try to get the run down the previous hill and keep the boost at 10 #'s going down hill. I then keep it there as long as I can, down shift 1 gear and keep it there until I have to boost it up.
    I was also thinking of the " get over quicker with more fuel burn as opposed to slower and less burn" I'm mostly concerned with what's best for the engine. staying ahead of the power curve and burn the fuel or grind up the hill keeping boost down? I kinda stay on the side of being ahead of the curve and not lugging the engine. My max torque rpm is 1,200 so I don't venture much below that.
  9. vangtransport
    vangtransport Heavy Load Member
    863
    2,837
    Apr 14, 2009
    There isn't a way of knowing what the engine is doing at 10 psi to come to a determination of what's good, unless you have Insite hooked up to it, and duplicate boost every time the same way, with the same weight, same throttle position, same grade, same gear, same everything. Boost pressure with the ISX is tricky, but very important if you know the peak boost according to the calibration file. A example would be if you had a plugging EGR cooler, you can obtain well over 50 PSI on a climb, possibly to the point of blowing a clamp off, I've had it happen. You can also have really low boost due to a stuck open egr valve. On flat land if your at 10 psi, that boost could be from EGR or air, again it's impossible to know unless it's hooked to Insite. So to answer the question of what's better for the motor, simple, pay attention to your MPG with a calculator and change your oil well within Cummins recommendation according to your MPG.
  10. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    Boost and RPM are not indefinitely tied together.
    Turbos are variable. You can run 1300 rpm at 20 lbs and 1300 rpm at 50 lbs depending on the load on the engine.
    Engines haven't had a true "sweet spot" since ECM's and electronic fuel management.
  11. hellpatrol
    221
    172
    Apr 22, 2013
    And the search continues....
    In general I've found that 10#s gives me the best mileage. It's what I'm starting to see when I fill it up, which is every other day. I was curious as to what other people had run into and any tips they had, so I could keep them in mind as I hunted for the best point for my engine.
