Best Fuel Economy Practices??
Discussion in 'Prime' started by GlobalResponder, Mar 14, 2013.
  1. GlobalResponder
    GlobalResponder Light Load Member
    102
    48
    Apr 13, 2010
    Los Angeles, CA
    I see that the majority of the threads spend a great deal of time surrounding getting hired and what not to do once you're hired.
    I wanted to start a thread that is probably the biggest overhead cost of Prime and what I heard truckers try to do every day...SAVE ON FUEL!
    I would really appreciate the experienced guys to help us newbies out here and explain how it REALLY works to stretch your fuel economy.
    I don't think just a pad answer of "laying off the gas peddle is what I'm looking for". I'm looking for some really helpful advice on how you
    manage your rig every day on the highways.
    For example: Do you stick it on cruise and forget about it? What happens when you are reaching a hill, do you down shift immediately? Or is
    it better to put your foot down a bit to build up speed to gain further ground before your rig starts slowing down? What about when you crest a small hill (I don't mean one that is
    steep and requires down shifting), but a gradual grade. Do you drop it into Neutral and coast to save even more fuel? What about when you're in areas
    where it's up and down all the time and in rolling hills? Do you let your rig slow down in the gear you're in or do you shift down with the slightest drop in speed or rpm's?
    These are things I do all the time in my stick four wheel drive, but I'm sure it's not the same. As well as anything else you do to keep your economy where Prime expects it to be.
    How hard is it to keep it above 6.2 or 6.5? I think that's where I read on here where Prime REQUIRES you to be right? How difficult is that to do?
    Would be great to get your guys input from the experts.
    :biggrin_25514:
    Thanks!
  3. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    Reading green sucks:biggrin_25510:
  4. GlobalResponder
    102
    48
    Apr 13, 2010
    Los Angeles, CA
    Only green I see is the green behind my ears from being new! LOL..... :biggrin_2559:
  5. chemsoldier1
    chemsoldier1 Medium Load Member
    458
    210
    Apr 10, 2011
    Lufkin, TX
    You are going into the slowest trucks in the industry. Prime sets you up for success as they say. There are not a lot of variables that you can influence. I'd use pedal when in hills. Back off a little bit as you are climbing, and more importantly, find your engine's power band. If you have to back down a gear then do so. Try to time it where it can be done smoothly. Don't lug! If the truck runs smoother at 45MPH on the climbs at 1300 RPM in 9th gear than 1150-1200 RPM at 51MPH in 10th, then use 9th. Other things you can do is just be mindful of your acceleration and plan ahead. When in town, look 10-15 seconds down the road. If you can see multiple traffic lights ahead, just assume you will catch every single one at red. If the speed limit is 45 then just run 30. Even if the 4 wheelers get pissed and pass you. It lets you slow down easier and possibly keep from having to come to a complete stop at each light. Don't try to race cars or other trucks off the line just to get up to speed. Make it gradual. Don't pay attention when other truckers talk crap to you on the radio. Just maintain your lane integrity and drive smoothly. Same principle applies in heavy traffic on freeways. NEVER take it out of gear to coast! Not only is that illegal but you no longer have full control of your equipment when its out of gear. Especially going down a hill or other grade. In an emergency, you may not have enough time to find a gear to slow it back down. When parking, loading/unloading etc., pay attention to your APU use. Just because you don't have to idle doesn't mean that APU doesn't burn fuel. If its comfortable weather outside, crack your vents and windows and enjoy the breeze. If you can spend some time inside the truck stop without having to have the AC or heater run on that APU, you are also saving fuel. If you have the option available to do so, don't get more fuel than you need for the current run you are on plus some reserve. More fuel is just more weight to move. Keep your tires aired up, air filter blown out, and any other driver level maintenance you can do. Keep coolant topped off. IF its not cooling the engine then the fan has to come on which takes power from the wheels and forces the engine to work harder to move your load.
    jomar68 and postmandav Thank this.
  6. GlobalResponder
    102
    48
    Apr 13, 2010
    Los Angeles, CA
    Some great tips Chemsoldier, thanks! I hadn't thought about all the time you might spend with the APU running. I have actually gotten used to having no A/C, as I don't have A/C in my home since I live near the coast and my Jeep doesn't have A/C, so that suits me just fine. Unless the cab is baking, I imagine the windows rolled down will do the trick.
  7. Danfromwindsor
    Danfromwindsor Road Train Member
    1,632
    614
    Mar 26, 2010
    I disagree on the lugging,these new motors are designed to be lugged down and maintain fuel economy. i let my cruise go til the engine is lugged down to 1100 before kicking it off and down shifting. sometimes i may not have to downshift becajuse she will pull the hill at 1100. your engine has a higher horsepower rating while on cruise versus on the pedal if its setup like most companies. so to kick cruise off before you need to because you dont want to lug,you are robbing yourself of horsepower to pull the hill efficiently. on flat ground set the cruise and ride. 59-60mph keeps me in the right lane with minimal lane changes.
  8. Danfromwindsor
    1,632
    614
    Mar 26, 2010
    Also if I remember correct the Cascadias use a electric fan to reduce engine workload.
  9. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    They don't... it's a fan clutch.
  10. chemsoldier1
    458
    210
    Apr 10, 2011
    Lufkin, TX
    Maybe the '13s and up do but mine is a '12 and its belt driven with a clutch engage. Its possible though the newer ones may have this. I'm not sure as Prime has such a wide variety of trucks in their fleet. Its anybody's guess what he could end up in as a company driver. If he is flatbed he might end up in a Pete 387 or if he is reefer or tank he might get one of those new microliner "lightweights." Prime has one of the most diverse fleets of company trucks that I've ever seen.
  11. ironpony
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Hills... if you can get a little speed up on a downgrade, it'll perform better going up - but you don't want to put your foot in it. Do get the engine up from idle before you hit the grade, because there is a lag between power demand and when the turbo spools up. As you hit the crest, back out of it, and let the momentum of the truck carry you over the top of the hill. Using "Georgia Overdrive" (going downhill in neutral) is illegal, dangerous, and liable to get you and/or someone else killed. Depending on the grade, you may need to use your jake brake for speed control and/or downshift into a gear that allows you to control your speed with your jake. You should never ride your brake down a steep grade... on a hot day with a heavy load, brake fade will kill you.
