Best gear ratio for 15 speed
Discussion in 'Volvo Forum' started by 416autohauler, Mar 1, 2024.
  1. 416autohauler
    416autohauler Bobtail Member
    7
    Mar 1, 2024
    Hi guys, I have 2006 Volvo with a d12 and an eaton 15 speed direct transmission, I don’t think it has overdrive. It has a gear ratio above 4 but not completely sure. I haul a 5 car hauler so my loads are usually light and I drive on the highway in Ontario Canada where roads are majority of the time flat. What gear ratio do you guys recommend I change to as my trucks rpm’s are way to high at 100km or 60 miles. Which gear ratio should I change it to comfortably run at 100km and still pull a hill. Thanks
  3. Magoo1968
    Magoo1968 Road Train Member
    2,028
    5,418
    Mar 18, 2021
    St Malo mb
    Those years of d12’s weren’t very strong that’s why someone geared it that way.. I doubt if you pick up much for fuel mileage . It will take many years to break even , your best time to regear is when one rearend needs parts replaced..
    AModelCat Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    If the rear ratio is in the 4’s then it is definitely an overdrive. A direct would be geared something under the 3’s.
    I had a 15 over with 3.73 rears and a series 60. It worked pretty well.
    The 15 over had a top gear ratio of 0.79 vs 0.73 for a 13 or 18 speed.
    Joel Morrow said even the old D12 was a European engine designed to run really low rpms. With your lighter loads it would probably work well with something in the low 3’s for a rear ratio. Need to know tire sizes to get better numbers. Or maybe ask him on facebook.
