Best Least Expensive Steer or All Position Tires
Discussion in 'Ask An Owner Operator' started by scottcspear, Jul 5, 2020.
  1. scottcspear
    scottcspear Bobtail Member
    I have a 1969 KW900A that I am restoring for the sole purpose of showing. I am removing the stationary 5th wheel permanently and will be posting it for free. Its old but works and just needs a little cleanup which I will be doing, its free to whoever wants it. Just as a FYI, I am making the bed a flatbed, stake-side for it. The current tires are Michelin X brand tires dated 2008, good retreads on the back. Since I am only restoring it for the show circuit, never intending to haul a load again what would you all suggest for replacement tires? I'd like to get something that is all position, low profile if possible with descent tread patterns (safety is my biggest concern, not hauling any weight) with the lowest possible cost tire. The tractor weighs in at 12,410 lbs.
    What do any of you recommend as replacement tires?
    Thanks in advance for any help y'all may provide.
  3. abyliks
    abyliks Road Train Member
    3,925
    9,199
    May 2, 2010
    ludlow MA
    I would probably just run the Michelin’s out if your not going far with them, other then that about the cheapest I would go is Goodyear marathons, I wouldn’t put anything Chinese on the steer
  4. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Check out the yokahoma 617 looks good and reasonable price
    stillwurkin and Bean Jr. Thank this.
  5. 86scotty
    86scotty Road Train Member
    4,523
    12,235
    Aug 27, 2017
    Appalachia
    Yep, I wouldn't want to see a cheap Chinese steer on a show truck.
  6. thetransporter123
    thetransporter123 Bobtail Member
    22
    12
    Jan 5, 2013
  7. Capacity
    Capacity Road Train Member
    1,499
    3,118
    Jul 28, 2019
    Neenah Wi
    We always had good luck with Kelly Tires , way cheaper than Michelin or Bridgestone.
    86scotty Thanks this.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I buy BFG only steer/drives for years, reasonable price and i'm happy with quality, lasts as long or longer than more expensive top brands.
    I glide 47 and 86scotty Thank this.
  9. Long FLD
    Long FLD Road Train Member
    12,050
    49,707
    Mar 4, 2015
    Kelly has a steer/all position tire that’s usually priced decent that will fit your needs.
