Best MPG grossing 117,000 pounds
Discussion in 'Ask An Owner Operator' started by FoxHoleRnch, Mar 21, 2019.
  1. FoxHoleRnch
    FoxHoleRnch Bobtail Member
    17
    12
    Apr 25, 2018
    I'm about to sign a contract hauling rock 150 miles and then coal back. So i will be loaded both ways. I'm trying to decide what engine will give me the best MPG. The 3 engines I will pick from will be a 3406e, n14, 12.7 detroit. Truck has to be older than 2000 to stay away from elogs so I can get two trips in a day. It is pretty much all Interstate. I'm pretty sure the detroit is the best for mileage but everybody I know that has a Detroit doesnt gross that much.
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,450
    Oct 2, 2011
    Williston, ND
    Just to give you an idea. ( might be useless information lol )
    I have a performance ISX15 550hp/2050tq Cummins and I run 120,000lbs and average 2.9 - 3.8 MPG depending on hills.
    FoxHoleRnch Thanks this.
  4. Ruthless
    Ruthless Road Train Member
    8,989
    88,727
    Aug 28, 2010
    The City.
    One of my trucks used to run that kind of weight/ 12.7/18/3.90. Think he said he was under 4mpg average.
    TripleSix, wore out, SAR and 2 others Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    That kind of weights usually create a fuel burn of gallons per hour rather than how far you can go on mileage per gallon. It would take all the older two strokes could give and then some in those days.
    Goes without saying the more horse you have on hand the less work you have to do. So for that kind of weight I'll be looking to see if there are 750 HP or better engines in the USA.
    alds, WildTiger1990 and FoxHoleRnch Thank this.
  6. FoxHoleRnch
    17
    12
    Apr 25, 2018
    Ya I'm already planning on turning up the engine. My truck now has an 3406c in it and I average 4.5 mpg pulling a Hay train crossing around 110k but that is only loaded one way.
    x1Heavy Thanks this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    We haul 140,000 lbs, 65-70% loaded.
    Some guys get just under 4 mpg, a few break 5 mpg in the summer.
    Trucks at 500 hp or less seem to average better overall. Yes they are slower, but horsepower costs fuel.
    x1Heavy and FoxHoleRnch Thank this.
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    If your going for pre eld I would make sure the drive line is up to the task before I even worried about mpg at near 120k.
    You have a pre-eld C already. You know the truck and its quirks, why start all over again.
    alds, x1Heavy and FoxHoleRnch Thank this.
  9. FoxHoleRnch
    17
    12
    Apr 25, 2018
    Problem with the truck I have now is that it is geared so low its top speed is 65. So its tuff to get the 2 trips in a day without being able to go faster at times. Also I will still need it to pull my hay train. This truck will stay hooked to the double belly dump trailers and also the new truck will have another driver along with myself.
    x1Heavy and Brettj3876 Thank this.
  10. Brettj3876
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Ok I got you. What's the specs? Trans, rears, tire size?
    If you have the cash a 5ds '98 or 1mm '99 is what I'd be looking for. Good luck though
  11. Long FLD
    Long FLD Road Train Member
    12,044
    49,657
    Mar 4, 2015
    Since you’re going pre-eld, I would completely go through the running gear before it hauls a load. You don’t want to be packing weight with tired transmission and rears.
    A 12.7 at those weights could make for a long day.
    x1Heavy, alds, TripleSix and 2 others Thank this.
  12. FoxHoleRnch
    17
    12
    Apr 25, 2018
    Ya all I can afford is to dream about those engines. lol
