Best place to get SCR?
Discussion in 'Volvo Forum' started by ErieMcDreary, Jan 29, 2020.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    KB3MMX Thanks this.
  3. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Dealership called me back, knew I was a bit upset, no I didn't get belligerent or scream at them. They said they can do the SCR for $4600, part of the other charges included NOX sensors, which I replaced last August, cut that $1200 from the total bill, brings it down to about $6400, still working on that.
    KB3MMX Thanks this.
  4. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    I seen scr performance low, and a service scr needed. What does service consist of and why does yours need to be replaced? Is that what others call a one box?
  5. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    I think it depends on what year your truck is, for what a service consists of. Mine needs replaced because the emissions system was not serviced by the leasing company that originally owned it, at the correct intervals listed in the service manual, before I bought it. Mine is a 2016 with 560,000 miles on it, and is not the one box which is newer. Mine has the DPF and SCR separated, the one box has them both in one unit. It takes up less space and may be lighter. I just found out that Volvo won't cover it through their early emissions degradation program because it has over 500,000 miles.
    KB3MMX Thanks this.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    What year is the truck I got one on the floor only 6 months old pm me it will fit up to 17 Volvo
  7. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    so I deal with Volvo all day everyday for the last 12 years and have only had to ever replace one of these boxes. This is very strange needs to be replaced make sure they do not miss diagnose they could also be cleaned as well at the same that cleans dpf assy.
  8. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Wish I had heard from you a day earlier. Already have the new one installed.
    Back story; I bought the truck last June, 2016 VNL, from auction, for $25k, (most were selling for $35+) with 520,000 miles, so I figured it was a good deal. I got all service records and am familiar with maintenance of that fleet, which did not include any emissions system work as called for in the manual.
    Got on the road (after company paperwork) on August 1st, immediately got check engine light, long story short, over the last 5 months I have replaced DPF (too far gone to clean) NOX sensors, injectors and cups, 7th injector, EGR cooler, and now SCR. Without going back to add all that up, it's $15k -$20k. Asked about Volvo program for early degradation of emission system, told it's over the 500k cutoff. I'm planning to contact Volvo directly about that.
    I do have one other weird thing going on, since EGR cooler was replaced, my coolant temp doesn't go over 160-170, except on a long grade at low speed, where it will climb to 200 and the fan will come on. I asked them to replace thermostat, they did, but told me it still won't get any warmer than that. They suggested that since EGR is now clear it just runs freer. I'm hoping it will warm up under load, will know later today.
  9. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Still does not warm up, runs pretty constantly at 160-170. Dealer suggestion is to get a winter front.
    It does seem to pull a little better now.
  10. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    this is normal operating temp for D13 under low load and idle condition.
    KB3MMX Thanks this.
  11. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    I would not say that what you have replaced is unusual. At around 500,000 to 600,000 most of the above parts needed to be replaced because they have just worn out. Injectors and cups about the same, they seem to go at around the 500000 mark. Pretty extensive set of posts about injectors and cups here. The rebuilt injectors will last around 2 to 3 years maybe and I repeat maybe. Then need to be replaced. I did the same, pretty expensive yes, annoying as all hell yes. But since then the system has worked fine(except for the doser which I now replace every 12 months). The SCR hasn't needed to be replaced as yet, the volvo mechanic said that when it starts requiring parked regens that are close together that is a good sign that it is burning out and will need to be replaced. I asked to have the Nox sensors replaced and the dealership said they were working fine and would not replace them. You can have them do a system evaluation, they hook up the laptop and take your truck loaded for a test drive. Which is what I did, the laptop said it was at around 90 to 130 ppm but not coding so the system was good. All you can do is keep an eye on it, drive reasonably and it should be ok. My 2 cents worth anyways.
