Best route to fortuna ca
Discussion in 'Experienced Truckers' Advice' started by snicrep, Jun 5, 2024.
  1. snicrep
    snicrep Road Train Member
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    I'm in case grande az. Going to fortuna ca. I've come from there south before on 299. Very twisty. I'm going up i-5 and was wondering if 36 would be any better. Or maybe 20 at Williams west to 101.
    Thanks.
    The_vett and Flat Earth Trucker Thank this.
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,495
    Feb 15, 2014
    California.
    Hwy 36 is worse than 299 for being narrow and having curves. We run it with logging trucks and end dumps but a 53' would have you hating life. Don't try cutting off of 101 onto Bell Springs Road and cutting over to 36 that way. You'll probably be the lead story on the five o'clock news. They don't call that area Murder Mountain. for nothing.
    If you have a 53' trailer 101 is closed near Richardson Grove...length limitation . Don't think about trying to sneak through on 101. The CHP patrols that area out of the Garberville office and they can spot an over length truck real easy. They really look for them. Good source of revenue for the state and county.
    Stick with 299 to 101. They've done a lot of work on that road and other than a few places it's easy driving.
    Where are you going in Fortuna?
  4. snicrep
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    I'm in a 48' food grade tanker. But I'll still avoid it. Too bad california didn't make some areas more accessable.
    Flat Earth Trucker and The_vett Thank this.
  5. snicrep
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    I-5 to 299 it is.
  6. snicrep
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    The dairy. I forget the name.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,834
    18,726
    Nov 1, 2010
    Burnsville, MN
    CA is not a friendly place, especially for trucks.
  8. snicrep
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    It's a good feeling when I leave ca and can go a reasonable speed.
  9. REO6205
    13,168
    60,495
    Feb 15, 2014
    California.
    The one at Fernbridge? It used to be called Humboldt Creamery but Foster Farms owns it now.
  10. snicrep
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    That's it. Humboldt.
  11. snicrep
    1,338
    2,485
    May 13, 2009
    mcallen, tx
    Been there once b4. Came down from Portland. Went to hyrum ut.
    The_vett and REO6205 Thank this.
