I have a Predator 3,500 mounted on the catwalk. It'll run anything in the truck with ease. $900 with the 2 year replacement warranty.
5,500 btu GE portable AC (think R2D2) 1" ratchet strap holds it to the side of the passenger seat and vents out the passenger window. $300 also has Dehumidifier so when I use that I have short hose that i drop out under the passenger door.
Heat is a 1,500 watt portable heater (I run it on low (750 watts) sits on the floor in front of the AC $25
Battery charger is a 2/8/15 Amp, auto changing 2/8 and the 15 Amp is only for boosting. Sits on the floor behind the driver seat. $25 this keeps the batteries charged to run the TV and other things running off the invertor.
I use a 6 plug heavy-duty power strip for anything running off the generator.
My generator is so quite you can stand next to it and have a normal conversation. When set on eco mode it will run for around 12 hours on 2gl of gas (the fuel tank is 2gl.)
move your catwalk as far forward as possible and your hitch back as far as possible (slide it back) trailer nose swing Clarence, Mount the generator to the catwalk with ratchet straps i use 4. 1 on each end truck frame around the handel to frame, 2 catwalk over the top to the catwalk... you could flip the truck and it still can't move. 2 heavy-duty cable locks around the truck frame and locked to the handle (the handles are part of the genurator frame)
Fuel storage I have a outside frame mounted storage box that I keep 4x 2gl gas cans, each can is a full tank so that is 48hr + the generator tank equal 60hrs..
I've been running this set up for 3 1/2 years.
Keep me comfy in the south all summer even when it's 115° in TX - AZ And in the winter up north. I've had level 1,2,3 Inspections and dot have never said anything about my setup.1
Takes about 1hr to install everything (not counting moving the catwalk and hitch.)
After mounting the genurator run the power strip cord thru 1 of the preexisting holes under the sleeper.
Setup to use the AC is just open the passenger window slip the vent hose out (I have a piece hard foam to fill the gap, close the window then crack the drivers window about 1/2 - 3/4 in. for cross ventilation. Takes about 2min.
Heat no setup. Just turn on
Charger setup just open the driver door grab the alligator clips and hook up about 1min because you have to get out anyway to start the generator.
Maintenance is a oil change (20oz) about every 150hrs (about every 2 weeks takings 10 breaks) and requires NO TOOLS...
All in about $1,500
I know it's a bit long but I hope it helps answer you questions
Best rpm to idle for engine + hvac
Discussion in 'Ask An Owner Operator' started by Loudstacks, Mar 21, 2024.
Page 3 of 4
Fuel tank pulsar 1gl predator 2gl
Runtime pulsar 4.5hr predator 12hr
Starting pulsar pull start only predator electric or pull start.
Sound pulsar 59db predator 58db
Weight pulsar 47lb predator 100lb
Fuel Guage pulsar no predator yes
Warranty pulsar 3 years. Is this repair or replacement. Do you have to send it off for repair/ replacement, Predator 2 year free replacement if it breaks for any reason just take it to any harbor freight and walk out with a new one in the box in 30min..Last edited: Mar 23, 2024
And the start. Which my pulsar starts with one pull.
Runtime. If I had 2 gallons. Would be 9 hours at 50% load. Yours is 11 hours at 25% load.
Price point. $130 cheaper for the pulsar.
Size. Pulsar is smaller. And lighter.
50 lbs vs. Your 100ish.
I can stick mine in the truck very easily.
Wattage. Pulsar has slightly more.
Warranty goes to a local authorized repair shop. If I need to. I have another pulsar I can use. It weighs the same as yours and puts out twice the wattage. Has electric start. And I have a 40 pound propane tank. Or a 3.7 gallons gas. It runs on either.
Gas gauge. There's aftermarket caps with floats. -
AModelCat said: ↑How many horsepower are these APUs? Seems like 74 HP and up is the magic number where manufacturers start putting SCR systems on their engines.Click to expand...
Arctic_fox said: ↑Depends on the model. Mine is 37 but the crypack i had was 14 iirc. One i had at a diffrent company that used carriers all had def and were 11 horsepower.Click to expand...
AModelCat said: ↑Wonder if that's a CARB thing?Click to expand...
I don't have to find a shop. They tell me where it's at.
I have no problems hauling my generator. It'll store nicely under the bunk. It sits in my garage with no problems. Along with my motorcycle and other generator.
In today's world where gas fumes are tightly sealed. Except for my pickup. It didn't come with a cap. -
Most inverter generators have a small 12v outlet. I put a permanent female plug on the truck and bought a male to male cord. The only 12v stuff running when I’m parked is my fridge so it Dosent really need much. This system runs on 1 gallon or less on a 10 hr break. When I stop, I put the unit on the catwalk. Fill up with gas out of my 2 gallon gas can, plug in the shore power cord and 12v cord. Pull the start coard and enjoy my evening.
I run thes every single night I’m out. I change the oil usually when I change the truck oil (if I remember ( usually after 3 oils changes) but is usually once it shuts down in low oil) I replace the generator after about 1 1/2 years and sell the used ones for $100. The units can be found for less than $350 pretty easily. All this stuff gets stored in my tool box on my truck about 2 ft from the cat walk. I think I’ve been running this exact set up for 4 years now? Before this I had several different set up, generator types, storage solutions, air conditioning and heating set ups.
At the end of the day this works every day easy breezy and you couldn’t spend $600 if you tried to replace the whole system.
Sleeping at night without my truck rattling away? Priceless…Full Pull Florida, Magoo1968, shatteredsquare and 2 others Thank this.
Page 3 of 4
Related Categories
Any Auto Transport O/O's That...
MooneyBravo posted Aug 2, 2025 at 12:56 PM -
Tell me why I shouldn’t switch...
W923 posted Aug 1, 2025 at 10:35 PM -
The NIGHTMARE of HIGHWAY......
Not Right posted Jul 31, 2025 at 3:40 PM -
Spread with independent sliding...
Storm Trooper posted Jul 27, 2025 at 8:25 PM -
A trucking perspective from...
TheLoadOut posted Jul 27, 2025 at 5:17 PM -
LLC setup
NascarUno posted Jul 26, 2025 -
Delete it or now?
DeathByCheetos posted Jul 25, 2025 -
MC / DOT / Trailer for sale...
BarshayTrucking posted Jul 24, 2025 -
Anyone get loss of use while...
Stringb8n posted Jul 24, 2025 -
Who’s in and who’s out?
Midwest Trucker posted Jul 21, 2025
Loading...
Recent Threads
Good Drums and Brakes for heavy...
nikmirbre posted Aug 2, 2025 at 11:52 AM -
NORTHEAST REGIONAL
fcfightermma posted Aug 2, 2025 at 10:00 AM -
Truck Rips Down Power Lines
mjd4277 posted Aug 2, 2025 at 9:37 AM -
Hot Dog Spillage On I-83
mjd4277 posted Aug 2, 2025 at 2:56 AM -
I failed my driving test for...
omar1999 posted Aug 1, 2025 at 9:39 PM -
2025 LT cruise control weirdness
tarmadilo posted Aug 1, 2025 at 9:13 PM -
Getting my CDL CLASS A
TRAV OPTIMA posted Aug 1, 2025 at 9:02 PM -
My CDL training experience for...
BigWindy93 posted Aug 1, 2025 at 8:31 PM
Loading...
