best specs for hauling hay
Discussion in 'Ask An Owner Operator' started by Surayu Trucking, Oct 18, 2016.
  1. Surayu Trucking
    Surayu Trucking Bobtail Member
    Any hay haulers out there what do you have
  3. Eeyore05
    Eeyore05 Medium Load Member
    311
    287
    Nov 13, 2015
    'Sconni
    A John Deere and a hay wagon
    Big_D409, j_martell and Dye Guardian Thank this.
  4. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Or two...or three.
    In all seriousness, the only consistency to hay haulers I've seen is that most are open-deck. Though I know first hand of an outfit that hauls hay in vans in the northeast.
  5. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Whatever gets good mpg... Unless the bales are damp there is rarely any issue with weight. Only people I know that run hay are part of a co-op, and they load from the field and offload into the feedstores. Hay is just something to run after harvest to keep busy, can't imagine it paying too well unless a region is very drought stricken.
  6. AModelCat
    161,606
  7. rank
    rank Road Train Member
    9,919
    113,508
    Feb 11, 2010
    Depends on bale size. You can have 50k net with (60) 3x3x8 ft 825 lb bales on a 53 ft trailer so a light tare is good.
    MJ1657 Thanks this.
  8. Accidental Trucker
    Accidental Trucker Road Train Member
    3,409
    7,589
    Jun 4, 2015
    Around here, the trucks, trailers and bales are all held together with baling twine.....
  9. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    It's actually very easy to be overweight if hauling round or big square bales, not so much with small squares(idiot cubes). I run a 48x102 all aluminum flat with a 4' extension on the back, and only haul big bales. If hauling small bales then a step deck is definitaly the way to go.
  10. Short Fuse EOD
    2,786
    8,739
    Jul 29, 2015
    Midwest
  11. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    Being a part time farmer and owning a trucking outfit, I haul hay from time to time. It's always short hauls of 20 miles or so though.
    I've hauled both small squares and rolls on flatbed, step, and van. Step works the best IMO. Lots of tractors can't reach high enough to fully load a flat and if you are loading small squares by hand, flatbed can be murder.
    We've got a couple of old vans that we will load small squares in and just leave it there until it's fed.
    Although I've never hauled them, the big squares look like the easiest to haul. Small squares and rolls are a pain to tie down. If we are just hauling on the farm, we won't use securement. It will stay on pretty well if you load it right.
