Best Value/Reliable Truck for First Time O/O Not New
Discussion in 'Trucks [ Eighteen Wheelers ]' started by supertrucker79, Mar 15, 2020.
  1. supertrucker79
    supertrucker79 Light Load Member
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    Just wanted to get some thoughts on this subject. What is the best truck/driveline combo for a first time O/O that has the least problems and how much should you pay for this truck. What about glider kits? Setup is long haul for typical van/refer configuration. (80K gcwr) What are typical problems with your suggested truck and costs? How about maintenance recommendations on doing pre-repairs, over haul or in frame, ect. Let’s just cover the truck. No need to delve into the other O/O businesses aspects.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
  4. boneebone
    boneebone Road Train Member
    2,295
    2,366
    Mar 13, 2009
    If you don’t have a need to go to Commiefornia, the most reliable and least problematic trucks are Pre-Emission or Glider trucks.
    supertrucker79 Thanks this.
  5. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    How much maintenance do you plan to do yourself?
  6. DUNE-T
    DUNE-T Road Train Member
    6,939
    16,822
    May 10, 2015
    Detroit, MI
    With your budget you can get a really really nice fully rebuilt 98-99 truck. I would suggest a 99 Volvo 770, but I am biased
    Bakerman and supertrucker79 Thank this.
  7. supertrucker79
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    PM’s, tire rotation or replacement, parts replacement. Basically, anything that doesn’t require taking apart or pulling the motor and drive line.
  8. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    Can you do breaks, wheel bearings, do s cam bushings and slack adjusters? With an old truck, you will most likely have several sets that need all that replaced because your brakes won’t work properly and always go out of adjustment. That can cost money but if you can do it all yourself, you are gold. It’s easy but time consuming
  9. supertrucker79
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    Yep, can do all those things. I would outsource internal engine or driveline work. Lash adjustment, over haul, ect.
    Chubby Fly Thanks this.
  10. supertrucker79
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    Maybe we can break this down more. Let’s start with the assumption of pre emission engines.
    1) Cummins x15 common problems/costs
    2) Detroit 60 common problems/costs
    3) N-14 (never had one in a truck)
    I was going to add the c-15, but how much longer will parts still be available since the whole acert fail took them out of class 8 trucks in 2010, I think it was.
