best way to macon ga
Discussion in 'Experienced Truckers' Advice' started by poppapump1332, Aug 6, 2017.
  1. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    anybody know the best and shortest way to get from reading pa to macon ga?
  3. little cat 500
    2,048
    1,092
    Jan 17, 2010
    Abbottstown PA
  4. Badmon
    Badmon Heavy Load Member
    806
    1,502
    Oct 6, 2014
    Deep south
  5. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    95 to 85 is the shortest. Just plan on getting through Baltimore and DC either before the sun or after
  6. Opus
    117,313
    I live in south GA and am very familiar with this trip........if it were me, I'd take 95 all the way down to 20, cut across 20 to exit 113 and then south on GA 83 (pay attention when you get to Montecello), and then end up on 75 south........this does 3 very important things......you bypass Fancy Gap, I 77 into Charlotte, and I 85 / 285 in Atlanta.......it's 30 miles longer than 81-77-85-75, but it's well worth it
    baha, poppapump1332 and A21CAV Thank this.
  7. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    85/285 into Atlanta isn't bad if you're going south and make it through there before about 5 am. All the traffic on 75 will be going north at that time too.
  8. Opus
    117,313
    yep as is 77 south into Charlotte......that said, anything after 5 am or before 7 pm on either road is pure hell
  9. poppapump1332
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    yep that's the way I took sitting in columbia can I run exit 130 which is route 44/129 all the way to macon?
  10. Opus
    117,313
    yes, that's the way I usually run. There's a few small towns along the way, but it's still a good run.
    Pay attention when you get to Gray GA......there's a new bypass and your map or GPS might not have it. But it's pretty simple, right at the 4 way, and right when you dead end. You're on a good route
    You'll end up on I16 about 5 miles west of I 75
    poppapump1332 Thanks this.
  11. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    Elvis got there on a overloaded poultry truck .
    whoopNride and Western flyer Thank this.
