Best way to make sure the ABS light is working correctly?
Discussion in 'Trucking Industry Regulations' started by Moving Forward, Aug 26, 2023.
  1. Moving Forward
    Moving Forward Heavy Load Member
    737
    727
    Jan 14, 2014
    New England, USA
    I've heard the best way to make sure the ABS light is working correctly is to simply unplug the pigtail during the pre-trip inspection, so all lights go out, then just plug it back in and quickly look down the tank/trailer to see if the ABS light comes on briefly and then goes off and stays off.
    Is that pigtail test the best way to make sure the ABS light's working right, or is there a better way?
  3. skallagrime
    skallagrime Road Train Member
    3,850
    9,923
    Apr 10, 2012
    Indiana
    Pull on a slight angle to the left (drivers side), cycle your key off and on, light and trailer abs system should cycle
    tscottme, Moving Forward and Magoo1968 Thank this.
  4. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    Piece of black tape always worked for me. They don't call it "A-BS" light for nothing.
  5. Rideandrepair
    17,427
    56,532
    Aug 8, 2015
    Normal operation is as follows. Turn key on, light comes on for about 2-3 seconds, then goes off. That shows it’s working. If it stays on, or at any time comes on and stays on, there’s a problem. Blink diagnostic as follows. Turn key on for 1-2 seconds, off 1-2 seconds, on 1-2, and off 1-2, then on. Light will blink. Count blinks. Refer to Wabco or whatever brand system, (ecu) blink code chart. Fix problem, drive vehicle above 3-5 mph to turn light off. If light stays on, it’s either not fixed, or there’s another problem, repeat diagnostics and get new code. Repeat till light stays off.
  6. Arctic_fox
    4,345
    23,411
    Sep 16, 2016
    And that is going into my tips and tricks manual lol. Ive been a driver for over a decade now and never knew that....would have made repairs SO much bloody easier on my last trailer.
  7. Moving Forward
    737
    727
    Jan 14, 2014
    New England, USA
    Thanks for the info. I had one of our mechanics tell me yesterday to NOT keep doing the pigtail test, because he said that's causing moisture and other crap to get up inside there and cause a bad connection... which completely makes sense since our yard is frequently wet and muddy.
    Rideandrepair Thanks this.
  8. mjv2744
    mjv2744 Light Load Member
    57
    140
    Oct 2, 2021
    That’s an awesome nugget of information right there. Thank you rideandrepair.
    Rideandrepair and Moving Forward Thank this.
  9. Big Road Skateboard
    6,646
    37,318
    May 2, 2021
    I unplug it to check, do it at night with all other lights off.
  10. tscottme
    tscottme Road Train Member
    I checked it that way or like @skallagrime just turn the key off and back on.
  11. Concorde
    Concorde Road Train Member
    5,256
    18,374
    Jun 29, 2016
    West Melbourne Florida
    Mine comes on for a second when I apply the brakes..is that normal? I’m wondering because I never noticed it on other trailers I’ve had.
