Best way to prime c15 fuel system?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckNorris, Jun 10, 2016.
  1. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Isn't there also a fuel pressure spring in the transfer pump?
  3. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Yessir
    lilillill Thanks this.
  4. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    it doesn't matter how many filters are in a system, which ever is closer to the tank is primary, (premier, primero, primary) and yes there's a pressure spring in the pump, but that's just for the, pump the fuel pressure regulator is in the secondary fuel filter base right under the return line that comes from the back of the head, on the previous picture the one circled on the right.
  5. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    That is correct, the primary filter is always the first to filter in the system.
  6. serozhah
    serozhah Light Load Member
    284
    47
    Sep 8, 2013
    can i instead loosen that hose next to the bleeder hex thing? I think i stripped the bleeder hex port. So I wander if unscrewing that hose a little would do the same?
  7. serozhah
    284
    47
    Sep 8, 2013
    can i instead loosen that hose next to the primer hex thing? I think i stripped the primer hex port. So I wonder if unscrewing that hose a little would do the same?
  8. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    The primary filter is between the tank and the pump. It is the “first” or “primary” filter to clean the fuel. The secondary filter is between the pump and the head. It is the “second” or “secondary “ filter because it is the second filter to further clean the fuel.
    When changing filters on a Cat do the filter on the frame rail. Start the engine and get it smoothed out. Then change the filter on the engine. Doing this often avoids issues with changing filters. If you ran it completely out of fuel, good luck.
    Oxbow and spsauerland Thank this.
  9. serozhah
    284
    47
    Sep 8, 2013
    All this blog is BS. I paid 400 bucks for mobile mechanic to come. He sprayed a bit of starter fluid in the air intake and told me to make sure not to stop cranking until the engine is running. It took him 2 minutes to start my truck. No flipping loosening of hoses , and all the crap in this thread. First option has to be, spray the dam starter fluid. I've had it done like 3 times on this cat. Between running out of diesel, and it turned out my priming pump is leaking air, which shoves air into the engine fuel lines... It was a lot of "crap, not again, its not starting dam it lol"
  10. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Spray with that ether. Lol
    spsauerland and Oxbow Thank this.
