Best weighing system?
Discussion in 'Ask An Owner Operator' started by Wespipes, Dec 11, 2019.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    Looking for a weight system for my truck and trailer. Which is best? Rightweigh? Appweigh? Those are actually the only 2 I know. I run a 48' spread axle flatbed. Would like to know the weight on both axles on my trailer Individually. I'm not sure if I have 1 leveling valve for both axles or 2? Thoughts and experiences?
  3. Tug Toy
    Tug Toy Road Train Member
    6,990
    73,225
    Jul 4, 2015
    Corn field
    Just a regular air gauge is all I’ve ever used. 1 on the truck and one on the trailer. I’ve only had 1 weight ticket in 5 years. It was a trailer someone else loaded. It was not over gross. I was over on the trailer and I knew it based on the gauge. I chose to run it knowing I was over. I got caught. Not the air gauges fault.
    All those systems do is translate air pressure into lbs after you calibrate them. At the end of the day it’s all about air pressure in the bags.
    Dadetrucking305 Thanks this.
  4. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    I perfer the analog gauge from right weight as far as your trailer you will have to see how its plumbing is done and can be easily taken care of if that is what you are after
