What are some driving habits I can adopt to get better mpg doing about 7 now just wondering if i can do a little better thanks
better mpg
Discussion in 'Questions From New Drivers' started by padriver87, Mar 14, 2011.
Page 1 of 3
A few facts needed
1) What are you driving , how is it equipped drivetrain wise.
2) Where are you running.
3) What are you pulling / hauling.padriver87 Thanks this. -
Thanks
Im driving a 2010 INT, prostar with a 450 cummins and a 10 speed eaton fuller
Im running in the north east
I pull a 53FT reefer usually gross around 72kFLATBED Thanks this. -
Right now with WINTER fuel , your weight and where your running 7 MPG is not all that bad.
Do you have much idling , now that its warming up things will improve a bit. How long have you had this unit -
Iv been running it about a month i try to keep idle time to a bare minimum im just expireminting trying ro see what i can get
Ok, just my side of it. Your sig shows you are far more experienced than I, so these are more for the newbes who come to your thread.
1) actually check the tires pressure instead of just thumping.
2) rollercoaster the hills. Pick up a little speed (3-5 mph) on the downhills and use the momentum to help carry you up the next (rolling hills terrain).
3) gentle on the throttle. The only time I ram the throttle is getting onto the freeway on a short ramp.
4) keep the trailer as close to the tractor as you can for weight and turning/backing. Less wind coming off the top of the cab to the front of the trailer.
5) Run the speed limit. I run within 3 mph of the limit.
My pig went from 6ish to 7.5 when I took an effort to do these things. This was pulling heavy rigs (95k-103k gross, dry van or reefers) in WA/OR, I-5 corridor. Before you get up in arms over the numbers, it was a freshly rebuilt truck. I know they are a little high for those weights.scottied67 Thanks this. -
Watch the speed, idle, and jack rabbit starts is about all you can do. If you don't know it yet, search out the power curve on your cam. But from the looks of it, you are doing just fine. 7.0 is good in the NE.
padriver87 and scottied67 Thank this. -
Or do what our company super trucker gets 9 miles a gallon!
I felt like i was not doing something right with 6.5-7.0 gallon.
Driver manager had a metting and said i was getting pretty good milage??
I asked about Super Trucker and he said he aint got 6 miles average in 3 years~!
So i have to keep my mouth shut but last week he was telling everybody how great he was and started blabbing his mpg and i loudly said #########!scottied67 Thanks this. -
What's a "jack rabbit start"?
A jack rabbit start is a very rapid rough start watch a swift truck start out sometime you will see what i mean
Page 1 of 3
