Biggest cummins that can go in "small" T800?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JordanJay31, Mar 3, 2014.
  1. JordanJay31
    JordanJay31 Bobtail Member
    36
    Dec 23, 2013
    My fellow elders, I have a '99 KW T800 with a cummins ism. This t800 is the smaller of them, the one where the front fenders are not quite "full" front fenders. Being that the smaller ism is in the truck and the hole for the motor is spec'd for it, I am needing to know what the biggest motor I'd be able to put in my truck. I have an N14 I'd like to put in because the series 60 is probably 2 feet too tall. If any of you have had experience in this or any general knowledge it would be greatly appreciated. P.S. Would you be surprised if I told you that even Kenworth studdered when I asked them this... Cummins told me to call Kenworth.... Thanks guys
  3. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    I'd say a ism would fit.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    you can get a t800 with a c15 n14 isx or a detroit 60 series you just need the right mounts its the same frame and cab as the t600
  5. dirthaller
    dirthaller Road Train Member
    1,090
    12,404
    Sep 22, 2011
    Coloratah
    I'm guessing the OP has a T 800 112" which is going to be ISM, C-12, 11.1 Detroit....sized. Most T800 are 120".
  6. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    image.jpg Let's see if we can shoe horn this one in ? QKS60 up to 3000hp V16 60 liter .
  7. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    Where there's a will there's a way!
  8. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Just time and money !
    milskired Thanks this.
  9. JordanJay31
    36
    Dec 23, 2013
    I see dirthaller is following me and you are correct as far as the motors that came in the smaller of the two sizes. Where does the size difference lye? Is it in the area between tranny mounts and front axle?
  10. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    Do you have the short hood or the long hood?
  11. milskired
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    He had said he has the short. I drive a couple of them at my job and they have small Cummins in them. ISM and M11. Not much more room under the hood for something bigger. They have a long wheelbase they just have a shorter hood for tighter turning in Chicago.
