Billionth split sleeper question
Discussion in 'Experienced Truckers' Advice' started by mstrchf117, Feb 23, 2023.
  1. mstrchf117
    mstrchf117 Medium Load Member
    638
    1,450
    May 21, 2016
    Normally I don't use the split sleeper, don't want to mess with it, but right now only way to make otd on my current load. I'm in EST(PA). Had a delivery at 1930. Was in the door about 2.5hrs logged off duty. Drove 2hrs to shutdown about midnight. Went pretty much straight to sleeper. If I log 8hrs sleeper I'll have my full 11/14 back? Final delivery is 0900,
    tscottme Thanks this.
  3. keebler13579
    keebler13579 Heavy Load Member
    947
    1,860
    Nov 16, 2012
    You wont have your full hrs back. Dependong on how.much on duty time you used will determine hrs gained. If you were off duty for 2.5hrs only required to have 7.5hrs in sleeper. If you only drove 2 hrs after your 2.5 hrs off duty then you should have 9 hrs driving after yoyr 7.5 hr breakd
    Hammer166 Thanks this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,673
    18,444
    Nov 1, 2010
    Burnsville, MN
    Rather late to ask that question, and how much time (and sleep) are you going to lose waiting for an answer?
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    No you will have the 2 hours you drove after your 2.5h off duty claim. So you have 9 hours of driving left and 14 minus (D+OD) left. You will have this 9 and 12 available actually after 7.5h in the sleeper. Or you can wait until you have 10h sleeper about 10 am and you will have full 11/14 renewed.
  6. mstrchf117
    638
    1,450
    May 21, 2016
    Nevermind I'm just doing a 10. I drove for like 5hrs before the first stop. Idk what the point is.
  7. Long FLD
    Long FLD Road Train Member
    11,881
    48,762
    Mar 4, 2015
    You could’ve done 7.5 in the sleeper and gotten back 9 hours of driving. The 5 hours of driving before the 2.5 off duty don’t figure into anything once you do the 7.5 sleeper to get your break.
    kylefitzy and Hammer166 Thank this.
  8. tscottme
    tscottme Road Train Member
    It's best to have split-break in your mind BEFORE you start your day and to be 100% clear about how to do it or it is just too easy to screw up and have an "egregious HOS violation". I found when I tried to "rescue" a wasted long waiting period by trying to use Split-Break I wasn't sure I was doing it correctly and I also couldn't rest as my mind was racing trying to figure out if I was correct or how much time I would have once sleeper period ended.
    Compliments to the OP for posting a short and sweet question and not the typical "I was going from A to B because the boss wanted me to talk to a guy about the fishing trips they had in 1997 where they hooked this fish than was 10 pounds and then left it in a cooler in a gas station where Junebug used to work. Anyway I started at 6:17 and drove past the old square building as that was ....... How many hours can I drive?
    gokiddogo Thanks this.
  9. JC1971
    JC1971 Road Train Member
    2,666
    9,739
    Jul 29, 2013
    L.A.
    The time you use between the short break and the sleeper break is subtracted from what would normally be a clock with fully-available hours after a 10-hour break. You would then have to sit for the amount of time that you didn't spend sitting to complete a 10-hour break.
    As Long FLD said, since you sat 2.5 hours off-duty, you only had to do 7.5 in the sleeper. You don't have to only do 7.5 in the sleeper, you could do 8 if you want in which case you would only have to sit 2 hours off-duty to get the rest of your time back.
    Basically, it has to add up to ten hours except the sleeper break has to be a minimum of 7 hours and the short break has to be a minimum of two hours. 7/3, 7.5/2.5, 8/2, 7.25/2.75, etc
    I use it all the time. I've ran all the way from Washington to Arizona using split break because it was the only way to make the delivery on time after a long load late in the day. The amount of time you sit at a shipper over 2 hours can be subtracted from your ETA if you use split break. If you take a full 10-hour break it adds two hours to your arrival time.
    Also, if the receiver doesn't take long enough to unload you to complete your short break, you'll have to find somewhere to park on the street or a nearby truck stop and restart your break. That's one disadvantage, especially if there isn't anywhere to park.
    It's difficult to understand at first but extremely useful once you figure it out.
    lual Thanks this.
  10. Moosetek13
    14,673
    18,444
    Nov 1, 2010
    Burnsville, MN
    A long load time goes on to the back end of the load and they can reschedule it.
    I'm not doing splits or short breaks to make up for someone else's mistakes.
    This whole notion of cutting into my break time because sales or planners or shippers/receivers don't do things right is nonsense.
    All these JIT loads that HAVE to get there on time, with so little time to work with?
    They need to plan things better to allow more time between shipping and receiving times.
    RockinChair, lual and Nashville Thank this.
