black and decker
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by rickstephens, Jul 12, 2014.
  1. rickstephens
    rickstephens Light Load Member
    131
    19
    Apr 25, 2007
    Bought a refrigerator from Wal-Mart I've had it a few months now. But the compressor rattles on our wonderful roadways. Does anyone else have this problem. If so how cab I stop this problem. The rattling is driving me nuts. Thought about taken it off the rubbers bushings and setting in directly on the floor
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
  4. TommyGunzzz
    TommyGunzzz Bobtail Member
    22
    6
    Jul 5, 2014
    I had one too just died me a month ago. did the same thing your saying nothing you can do about but turn the music up
    Skunk_Truck_2590 Thanks this.
  5. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Put it in the passenger seat & wrap seat belt across.
    (Also qualifys you to put your hazmat paper in that seat with the strap holding it.)
  6. VagabondTrucker
    VagabondTrucker Light Load Member
    81
    30
    Jun 28, 2014
    Make sure you have the extended warranty so when the compressor goes out, you can pull into Walmart, get a new one, and keep on trucking!
  7. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Don't take it off the bushings they are there for a reason unless you want it leaking freon into your truck
  8. Ridgeline
    22,365
    115,995
    These are not made for trucks, the vibration coupled the use of a cheap inverter with the low voltage burnout aka brownout will destroy the compressor fast.
    cabwrecker and HalpinUout Thank this.
  9. purpleprime
    681
    720
    May 30, 2013
    spickard, mo
    They only need a little over 100 watts to run and that's just at startup once its running it doesn't even register on my inverter I had one lasted 18 months for 150 bucks and lasting that long in a freight shaker it was worth the money so I bought another
  10. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Hell yea considering the dealership fridges are almost $800 bucks and don't have half the room inside.
  11. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    I'd just as soon buy a Coleman cooler with a peltier unit on it, and instal a more powerful fan ontop.
    Works just as well assuming you're not opening the door every two hours, and not trying to freeze a turkey in it. Hell, mine would freeze everything in it, when I put a new and better fan on it.
    The beauty of a solid state cooling unit, is that it will run forever if it's cared for, properly. The downside is, it's still in a truck. And that destroys everything eventually, moving parts faster than anything else. Buying a fridge with a compressor (IE: 4 sets of bearings just on the motor and compressor) that isn't made specifically for a truck, is like asking for a bottle rocket you can shoot to the moon. You won't find it, and it won't work out.
