Hi everyone, I've been out with my dad on the truck through some really nasty weather in northern Illinois and into Wisconsin today. We had to stop twice because the roads were looking bad. My dad, who has been driving a truck for 34 years, just seems to know when it's time to get off the road. Me on the other hand, I have no idea how to tell the difference in snow pack, black ice, and just wet road. If I decide to become a truck driver, I would really like some advice in how to tell the difference in these road conditions. Any help would be greatly appreciated.
Black ice or just wet?
Discussion in 'Questions From New Drivers' started by TriPac Dude, Jan 27, 2014.
Page 1 of 5
If there's spray coming up off of other vehicles, it's a good indication you're not on black ice. That being said, conditions may be right for it to form on overpasses and bridges. Use common sense, look ahead and others around you, maintain a safe operating distance that's more than usual for normal, dry conditions.
Cman301, heyns57, Working Class Patriot and 2 others Thank this. -
In my limited experience, icy roads have a dull shine to them.
They also appear patchy or streaky in sections.
Wet roads are fairly consistent.
But they can change VERY quickly.
Look at the weather around you, is it cold or windy, or both? Is it raining? Snowing?
These all affect how the roads behave.
As well as what you should be doing to ensure your safety and that of your equipment and your load.
If you have spray coming off your tires, you have wet roads.
If you don't have spray, park the truck until your confident that it can be moved safely.TriPac Dude and blairandgretchen Thank this. -
Easiest way to tell....Look at the ribbon ahead....Oh wait change that....Look in the ditches on either side of the ribbon....You see any FedEx "Single-Props" "Parked"?.....
There's Black Ice on the ribbon.....
Sorry...I had to do that.....joseph1135, blairandgretchen, HotH2o and 7 others Thank this. -
If your in Wyoming it's not wet. It's likely ice.
Moon_beam, joseph1135 and blairandgretchen Thank this. -
Most trucks have a outside temp dash readout. If not, get an add-on one, they're cheap. Or ask other truckers on cb what the temp is. Huge thing is to always look to see if spray is coming off my tires and/or other vehicle's tires. If not, then it's about to get icey, as in dicey. Slow down then. If it's in 20's, then more than likely black ice is out there, unless road crews are spraying that nasty stuff on roads. Again, look for spray off tires to see if it's working. Also you can try and feel if you get tire spin by giving the trk a little 'gas pedal'. When in doubt, slow down or get off road. No point in driving 25-35mph unless u can't pull over somewhere.
Working Class Patriot, TriPac Dude, blairandgretchen and 1 other person Thank this. -
Also check your mirrors to see if ice is forming on or around them. This will normally occur before it begins showing up on your windshield if your cab is heated up and the interior is warm. If you do hit a patch and feel the tractor get loose, don't panic. Don't accelerate, hit the brakes or steer left or right. Just hold it steady and straight.
blairandgretchen, Hammer166, Criminey Jade and 1 other person Thank this. -
Look at car and truck antennas if they are whipping excessively they are coated with ice. Look at your mirror brackets for a coating of ice on them both fender mirrors and west coast mirrors.blairandgretchen Thanks this. -
Also, just to add.
Look at your ATLAS, know where the rest stations are or the nearest safe spot to stop, Truck Stops, etc.....blairandgretchen and Working Class Patriot Thank this.
Page 1 of 5
