Blew freeze plugs to head???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, May 12, 2011.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    Blew freeze plugs/ soft plugs on new head... any ideas why???? The head is from cat and only has 11k on it...
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    possibly not installed correctly or incorrect plugs or head not machined correctly.
  4. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    could be too much pressure in the coolant system (ie) defective radiator cap, freeze plugs not installed correctly from the factory, not the correct coolant/water mix (causing a higher temp), stuck thermostat, not properly operation of the cooling fan (causing the temps to rise),
  5. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    I would guess improper installation, wrong plugs. Hopefully you can just hammer in some new ones without installing another head.
  6. brenes-built
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    I have the extended life coolant from cat in it..you don't have to mix it right, thats what the parts guy told me. I'm at Rush in El Paso, they put it on their computer and no codes, no high temp, and no compression difference...
  7. Rerun8963
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    glad you said......."no compression difference", because after i typed this, i thought about a possible leak at the head gasket, forcing the plugs to pop out under compression....i'd have the compression checked with a REAL compression gauge, NOT a hand held or stationary computer.....
    have it done with the engine cold, as when it warms up, any leaks may seal themselves back up again...... could be when the heads were torqued down, it was improperly done in sequence OR not torqued to specs, OR Cat may use a "torque to yield" specs, the mechanic was not aware of...this "torque to yield" needs another gauge besides a torque wrench.....it's a "torque to yield" gauge, like a dial indicator....
    i simply DO NOT trust a computer over REAL HANDS ON work........
    Oldironfan Thanks this.
  8. brenes-built
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    Yeah I tried to have them put the plugs in it and some antifreeze in the radiator, then run a compression test... But they didn't want to because of the warranty it might void with the Cat head..
  9. Rerun8963
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    i do not see how testing for a problem will void a warranty..sounds to me that they are a bunch of hacks.....any mechanic worth his salt will want to get to the bottom of this.....i know as a former mechanic myself, i would have.....and HAVE......even the best of the best can mess up, it's how they rectify the problem that makes them shine....right now, all the polish in the world can't make those turds shine.......
    Oldironfan and brenes-built Thank this.
  10. brenes-built
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    We must think alike... That's the same I was thinking when they told me that crap.. I'm back at the shop because they said they would get to it today, but now its in the morning.. A truck came back with an electrical problem and it just happens to be the mechanic has to be fixing that truck before mine.... :biggrin_25510:
  11. Heavyd
    7,812
    6,265
    Feb 4, 2009
    How does compression leaks blow out a frost plug and not the rad cap?
