Blind Side Backing
Discussion in 'Experienced Truckers' Advice' started by Bucktrucker, Jun 9, 2011.
  1. Bucktrucker
    Bucktrucker Medium Load Member
    453
    148
    Dec 10, 2008
    ON THE ROAD SOMEWHERE
    So here it is . I know im not the first to ever do this but i though i would tell others that don't know about this . First off if you dont have a window in your sleeper than this aint for you . If you do have one here goes. When you have to blind side just take the curtain off the window and its just like backing a day cab, You can see everthing you need to. I was watching a usa truck try to blind side back in a tight spot this morning and after a few atemps i went over and shared this with him . Well at first he really didn't want to listen to me but after he did well he put it to the dock the first time. Maybe it will help others.
  3. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    What? You mean they don't have all those little cones set out for you?
    Wargames and trucker_101 Thank this.
  4. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Ain't got no stupid little window, and I can blindside just fine. A little practice and don't over-steer.
    Diesel Dave Thanks this.
  5. BigJDub
    BigJDub Light Load Member
    100
    52
    May 26, 2011
    Crescent City, Ca
    No disrespect but if you good with your mirrors its not that hard. Any one here been to the US mint in Philly? I used to do that with out a ground guide. Forced blindside, once backed in there is maybe about 50 feet between your front bumper and a several foot thick reinforced wall and your putting it between 2 other trucks most of witch have EX hoods.
    I did this back 3 times a week for nearly a year and the only thing I ever did was lightly brush the bumper guide on a W900L. Left a slight scratch on it. Driver didn't even care when I offered to replace it.
    You just need to have a good sense of where your truck is. Be able to tell where the trailer is based on looking in the left mirror and seeing how much of the front of the trailer you see. Having good mobility of the power mirror on the right side is a big help. But then again its not something a student should be trying that's for sure.
  6. rachi
    rachi Road Train Member
    4,246
    5,230
    Feb 25, 2010
    SoCal
    Its never fun to pull into a shipper or receiver and see that its gonna be a tight blindside. Although in 5 years I have only had to do it a few times.
  7. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    I have to do it a couple times a week between two other trucks usually. At first it was intimidating, but after a few times I gained a little confidence, and it does get easier the more you do it. And watching others have to do the same thing also helps.
  8. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    i love my daycab
    Marksteven and oldmack Thank this.
  9. Sequoia
    Sequoia Road Train Member
    2,692
    1,793
    Dec 4, 2010
    Tampa Bay, FL
    I drive with all the curtains up, including the cab curtains! (keeps it cooler inside the truck so the A/C doesn't have to work as hard) I also close the divider curtains like I'm a flight attendant closing the curtains to First Class...with that smug "maybe if you worked a little harder in school you'd be sitting up here instead" look.
  10. ironpony
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Yeah, but being confident in yourself and your abilities to do a blindside back is worth it's weight in gold on the day you need to do it.
    When you pull into a nearly empty parking lot, go find some place with about 4 or 5 empty spots next to each other and practice! That's all it takes... and you don't need a daycab or a sleeper window.
    tinytim, scottied67 and rachi Thank this.
  11. Lonesome
    Lonesome Mr. Sarcasm
    10,968
    22,287
    Dec 15, 2007
    Northern Indiana
    I had to do a blindside inside a building once, between two other trucks,because they were doing some construction to the building, but weren't quite done. That was an experience.
    Just take your time, G.O.A.L a few times, it was OK.
    scottied67 Thanks this.
