Just got my clutch replaced but now my lights turn on but won't blink. Not even the lil arrows on the dash show up. What could be the issue? fuse? I have a 2000 freightliner century dd series 60 meritorious transmission. What fuse would control this?
blinkers arent blinking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by txnewbee, Feb 10, 2013.
Page 1 of 3
Sounds like you're out of blinker fluid.
Hardlyevr, Giggles the Original, aiwiron and 2 others Thank this. -
We have a 2012 Cascadia... There are two fuse blocks for us... One in the glove box area, and one near the firewall driver side... There is a turn signal relay that went bad for us, changed that and all was well... Check your owners manual or fuse diagram near the fuse blocks to see we're it is...
txnewbee Thanks this. -
His clicker quit qlicking.aiwiron Thanks this.
Yea I had a signal light bulb blow out. All my blinker fluid leaked out before I noticed it, man, was my boss ever po'd at me. After that I check them all the time and made sure I know where the cutoff's are!
I had a classic that always was blowing relays.once my mechanic found the right one we marked it with a orange marker so I could figure out which one it is.the light are on but they wont blink
My binky stopped the other day.
Dude.....I hear there is a operation and some med's that can help with that.aiwiron Thanks this.
Got me some thar blue pills in a pez dispenser, momma died with a smile the undertaker could not take off with a disk grinder.
Plz do not mix all stuff.
'00 Shaker got simple blinker relay mounted in PDM, like many trucks before 2002
From 2002 electronic light control apeared. In Cascadid Front (Cab SAM) and chassis SAM turn on off every lamp with power MOSFETs, the similar system with Actros MP-II (yep, both truck are made by Daimler).
Volvo imtroduced LCM on version-2, MAN - ZBR, Iveco - body unit... Paccar - VIC... so new trucks are with electronics (not trucks only, for example ford introduced electronic light control in 2001 with FEM and REM)
Page 1 of 3
