Blocking off Waste Gate???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Scrapper, Feb 14, 2012.
  1. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    The previous mech at our shop went around and crimped or cut and plugged all the wastegates on our turbos. I know the primary purpose of these is to allow engine rpm to rise some before kicking in the turbo so you do not have as much lag. Do these have any other purposes. Will doing this cause any problems down the road?? We have a couple 3406c, quite a few 6nz's, and a MXS. They have all been done this way. Is this a good or bad idea. He has also gone in and turned the fuel as high as he could on the ones he could get into with CAT ET...without a tune...The only one he couldn't mess with was the MXS...he didn't have a password.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    waste gate is a thing to prevent boost lines damage, engine overboost. Engine with higher then rated boost pressure runs at lean mixture, with higher internal temperature and more NOx emissions. Melt pistons, toasted valves....
    VisionLogistics Thanks this.
  4. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    Not a good idea in my opinion. It will certainly make more boost, but you risk over speeding the turbo, leading to premature failure.
  5. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    Okay, figured that. They have been disabled on our trucks. I know what he was trying to do...just not a safe way to do it. We have been redoing alot lately. Seems like we have some more to redo.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Mercedes engines store codes in case of overboost
  7. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    Wouldn't you adjust the waste gate to correspond with the amount of fuel you add when you add fuel?? Seems to me he just pumped the fuel and let the turbo be free to do whatever. How would I go about trying to get them back functional and set correct with whatever he has done to the fuel?
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    to do it you need Detroid Diesel cal. tool and some experience how to tune engine up and not to blow it
  9. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I definitely wouldn't do it to the MXS.
  10. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    Jfaulk...you wouldn't hook it back up?? Or take it off. My question isn't to take it off...I like things to work and do as they should. The previous mech did this. I'm just wanting to get it back right. And hopefully increase the longevity of the equipment.
    Pablo...can it not be done through CAT ET?? Is there a default or flash I could get to get it back to stock settings then plug the wastegate back up? These things are driving me nuts. We keep finding things that were done without longivity or dependability in mind. I know if he cranked up the fuel...then unpluged the waste gate to try to get more air to try to level out the A/F ratio...if I plug it back up...I'll get a rich condition right?
    Anyone else ever have to go back and redo what was done and you didn't have anything to do with it? lol. :biggrin_2552:
  11. Scooter91
    Scooter91 Bobtail Member
    10
    9
    Jan 15, 2012
    St. Cloud, MN
    You cant run a diesel lean, I have a turbo on my pick up that can supply enough air to support 800hp but I do not have the fuel to efficiently spool the turbo to get 800 hp. With more air you will get cooler egt's, when you dont have enough air for the fuel is when you get the black smoke and the higher temps where you will melt the pistons. But i do agree that clamping the waste gate will cause overboost and wreck the engine and turbo if the supporting modifications are not done to prevent damage
