Blow by on fresh rebuild?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, May 14, 2019.
  1. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Not my truck but a buddy of mines that just brought his truck out on road today.
    His truck went into cat for major blowby and oil loss. Cat did 20something thousand dollar over haul. Gets to the site today and ask me to look at a concern of his. The blowby tube wasnt chugging like a freight train but sure has a tone of steady flow of steam coming out. I went and pulled his dipstick and that son of a gun was pushing alot out of the tube as well. So we go over to my truck which has 300k miles on cat rebuilt from same cat dealer. Virtualy nothing out of blow by tube and absolutely zero coming out of the dipstick tube. So comparison on same conditions. HE took video of the blow by on his truck and a video of mine and sent to service manager.
    So my question is for those that have experience with this. Is this normal?
    Of course the motor is warrantied.
  3. OldeSkool
    OldeSkool Road Train Member
    1,907
    5,871
    Jul 17, 2018
    New Hampshire
    Doesn't sound normal to me. My truck has 200,000 on rebuild and very little blow by and none from the dip stick tube
  4. Cam Roberts
    1,621
    1,938
    May 13, 2018
    doesnt look normal to me either
  5. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,116
    Jul 12, 2017
    Did he break it in? I have had many Cats slobbering like a stuffed pig after inframe. Work them hard to seat the rings. Cylinder pressure is needed. Should get better the more you work it.
  6. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Today was first day heavy. Ill tell him to run it hard which i think he was. thanks
    Goodysnap Thanks this.
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    ACERT or pre-ACERT engine? Like @Goodysnap posted, run it in for a week and see what happens. Needs good load to seat the rings. Did he put a new turbo or air compressor on it?
    Cam Roberts and Goodysnap Thank this.
  8. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    +2. It needs more heavy work for proper break in.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,391
    7,867
    Jul 11, 2012
    in the bush somewhere
    Can't expect much the first day of working it. By the sound of it, it may be worse than what would be considered normal, but it really needs to be run a bit before it's condemned.
    My last truck had a rebuild done at Cat, and it was about 25000 miles until it quit slobbering and using oil. But after it quit, I didn't add a drop of oil between oil changes.
    Cam Roberts Thanks this.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    When I worked at Cat most trucks got ran on the chassis dyno for an hour or so under a pretty good load after a rebuild. Our marine and generator engines got that same treatment.
    joey8686 and Cam Roberts Thank this.
  11. Cam Roberts
    1,621
    1,938
    May 13, 2018
    pre accert.
    Cat did the package below the best one. Platinum? The reused things like the turbo-air compressor and i think injectors and crank.
    For a few grand more, i would have gotten the best package but the guy is a bit of a cheap ###
