blow by
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jmarsh91, Sep 26, 2013.
  1. jmarsh91
    jmarsh91 Bobtail Member
    46
    Aug 26, 2013
    baxley,ga
    im not shure if i have to much blow by since ive learned from some of the members on the forum my frieght shaker with dd s60 naturely has blow by. but i was wanting to know how to reduce it i just got the truck recently so im just gunna assume its in need of a oil change. but would that help reduce blow by? no oil comes out of the blowby tube just steam and a slight drip. and advice would be greatly apreciated.
  3. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    2 Gallons of
    [h=3]Lucas Oil With New Oil Change[/h]
  4. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    I also would like to know if i were to buy a truck, and have engine checked for blow by, how much blow by is bad enough to not buy the truck. Is there a chart that we can go by to determine what is acceptable or not?
  5. biofumes
    biofumes Light Load Member
    202
    96
    Feb 13, 2009
    California
    I had posted earlier about blowby on D60 series 2000 yr, non egr. I had taken it for an electrical issue, and the service tech began to state how bad blowby was on my engine, so on etc.
    I had the electrical issues looked at and had it put on the dyno, when the master tech came out to explain why the truck has blowby, he said this model year engine has a seal that when idle, it is completely normal, once it accelerates, the seal closes.
    Have it set to 435hp, and dyno came in at 408 at the wheels. So in this case, blowby is normal, and means absolutely nothing is wrong with it, other than normal operation. It seems the service advisers are just there to pump money out of you.
    Just another reminder, stay away from dealerships.
    ChromeNut and jmarsh91 Thank this.
  6. jmarsh91
    46
    Aug 26, 2013
    baxley,ga
    thanks man that is some good news
  7. jmarsh91
    46
    Aug 26, 2013
    baxley,ga
    well my blow by might be a bad thing....i got a small amout of coolant in my oil and a decent amount of oil in my coolant
  8. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    From all the things that you have said are wrong with that truck, I hope you got it for scrap price.
