Blowby from oil fill cap
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cubillos389, Aug 30, 2017.
  1. cubillos389
    cubillos389 Bobtail Member
    CA
    Hello all, I'm rather new to this forum.
    I've been having issues with a lot of white smoke coming from my oil fill cap. The truck is a 2008 Peterbilt 389 with a 550 ISX. When I bought the truck about 8 months ago, it had been rebuilt at a million miles and currently has about 120k on the rebuild. The DPF was clogged when I bought it, I had it deleted and the ECM tuned. Since then I've put a turbo on it since before the delete it had been leaking oil from the compressor side, so I just replaced it. I get good fuel mileage for what it is, average is 6.8-7.0 with no lack in power. I put a hole in the crankcase breather to relieve some of the crankcase pressure, but I still get a lot of blowby out of the oil fill. I change my oil at 13k, filters every two changes, and I only use up maybe a half gallon of oil every change. I'm not burning any coolant and I don't get any issues with overheating or lack of power.
    Any ideas?
    Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Are you sure it is excessive? All engines will vent some blow by out the oil fill with the cap removed.
    SAR Thanks this.
  4. cubillos389
    CA
    More so when the engine is warmer, my oil temperature sits at 220-225 degrees. On the occasion that I have to drive into some dirt, it sticks to the area around the oil fill cap and the fill level tube.
  5. Dave_in_AZ
    387,501
  6. Heavyd
    7,773
    6,211
    Feb 4, 2009
    Ok, there are proper ways to test for this. I recommend having a shop perform a proper blow by test to make sure.
    cubillos389 and SAR Thank this.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I would take it back to the guy who did the delete and have him look at it
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yeah, tell him to DELETE all this blowby while he's at it. Lol!
    Bakerman and cubillos389 Thank this.
  9. cubillos389
    CA
    I'll see about getting to the shop. I do a really hard Almond haul here and it's very hard to miss a day of work
  10. Heavyd
    7,773
    6,211
    Feb 4, 2009
    Well, if you can't miss a day for a simple blow by test, good luck to you if your engine needs any major work!
