Blower motor resistor
Discussion in 'Freightliner Forum' started by crobin29, Feb 8, 2014.
  1. crobin29
    crobin29 Bobtail Member
    Eldorado, OK
    Sorry for the dumb question but can anyone tell me were the blower motor resistor is on an '05 Columbia? I assumed it would be close to the fan but I can't find it for the life of me. The fan had been making a little noise and then one day it started blowing the 5 amp fuse when I turned the fan above half speed. I replaced the fan but still have the same fuse problem. In hindsight, I probably should have started with the resistor, but I can't find it anyway. Can someone enlighten me please?
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It's right under the blower motor inside.
    Here's a YouTube. :)
    [video=youtube_share;UPUGZ5Aq2hQ]http://youtu.be/UPUGZ5Aq2hQ[/video]
  4. crobin29
    Eldorado, OK
    Thanks for the reply. I found that video earlier but my mess looks nothing like what I see in the video. My motor is turned so it mounts vertical instead of horizontal. Also my fan has 4 wires running to it instead of 2 like the fan in the video.
  5. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Follow the wires should lead to it. Some of these newer trucks run through a BCM. I'll dig and see what I can find. Did you look on the firewall outside near the blower motor?
  6. crobin29
    Eldorado, OK
    No but I will check
  7. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    baha Thanks this.
  8. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    If you have an 05 freightliner, there is no blower motor resistor. The blower motor is controlled from the front controller by a PWM signal. I would disconnect the blower motor and check pin drag at the blower motor pins. Those pins become weak and like to spread
    CondoCruiser Thanks this.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    in 2006 BEGR started to use brushless motors so there is ESC unit there. be sure what kind of motor. My truck got brush motor with PWM control, friend's truck - brushless motor
  10. magnum2
    magnum2 Light Load Member
    111
    11
    Apr 25, 2014
    Pablo, I know you should have the answer to this:
    Here is my situation, I do not want to waste money for things that are not broken, my cab blower motor stopped working.
    Here is what I've done: I've pulled the blower motor out and connected it to the 12v battery, directly, and it worked fine. So, I'm thinking that my blower motor is in working condition. Correct?
    Now, I'm not to electrically savvy, so, here is what else I've done: there are 3 plugs on the blower motor assembly. One plug, two wires, connects to the motor itself. Another plug, bunch of wires, connects to what looks like the heat exchanger - shaped like half moon, and bolts to the motor housing with two torx screws. Third plug, looks like it connects to the "thermometer"?
    Next, I've put the volt meter on the plug that connects to the motor, while the plug is connected to the motor. With all of the plugs connected my reading was zero Volts. If I'll unplug the motor plug, and still keep my multimeter leads on that plug, the reading will jump to 12V, depends on the speed that is on the fan setting. Voltage would fluctuate if I'll change the fan speed setting. If I'll plug the plug, from the wiring harness, back into the motor, the voltage would drop to zero volts. Also, if I'll unplug the plug with multiple wires, from the half moon shaped heat exchanger looking thingy, and keep the motor plug unplugged then the reading will drop from 12v to zero V. If I'll plug that plug, from the half moon looking thingy, back in, and keep to motor plug unplugged, then the voltage reading on the motor plug will jump up to 12 or so volts, dependent on the fan speed setting.
    By the way, the blower fan and climate control in the bunk work fine. The above issue is in the CAB portion of the truck.
    ANY IDEAS WHAT IS WRONG OR WHAT I NEED TO REPLACE?????
