Blower not blowing air through vents
Discussion in 'Volvo Forum' started by humnbass, Nov 3, 2021.
  1. humnbass
    humnbass Bobtail Member
    26
    7
    Sep 15, 2021
    I just purchased my first truck which is a 1999 Volvo VNL610. When I turn on the blower for the heat/AC from the dash, I can hear the blower motor blowing as it should but it's not blowing through the vents. Can someone advise me on how to fix this?
    thank you.
  3. BobROss
    BobROss Bobtail Member
    have you looked to see if there is a blockage at the motor? maybe evaporator fins are clogged? are all the tubes connected?
  4. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    If you need to replace the blower motor, there's a video. I'd start by making sure the vents are actually open. Then I'd make sure the condenser isn't getting plugged with debris or freezing up. I've only taken mine apart once to replace the thermostat. I'm not sure if you could use compressed air or a shop vac or leaf blower in the vent to check for blockages. Just be careful not to damage the condenser, and make sure you don't lose any of the plastic gears or pieces that control the blend door. I personally would just replace the blower motor if it's only like $200, but there's probably a better way to diagnose it before throwing parts at it.
  5. Siinman
    Siinman Road Train Member
    5,436
    13,974
    Mar 5, 2017
    Kansas City, MO.
    Is it blowing in the dash or floor? If so it is the actuator. If it is not blowing at all then it is the blower and easy to replace on your own. Take dash apart and replace.
  6. humnbass
    26
    7
    Sep 15, 2021
    The fan is blowing but the airflow is not coming through the vents or the floor. Its definitely blowing though.
  7. beastr123
    beastr123 Road Train Member
    2,917
    23,904
    Jan 2, 2014
    Moose Jaw SK CAN
    Check for a plugged cabin air filter. It is outside on the passenger side up by the windshield if I remember right, 2 or 3 screws and you can pull the old one out.
    loudtom Thanks this.
  8. Daddee01
    Daddee01 Bobtail Member
    4
    Check your filter. Dash filtet. Air filter
  9. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Mice may have plugged it up...
  10. Fernandez
    Fernandez Bobtail Member
    8
    Change the blower. is on the passenger side very easy to replace i have change 3already. not expensive
  11. RoadRanger^^
    RoadRanger^^ Medium Load Member
    314
    116
    Apr 17, 2018
    Columbus, OH
    I remove the blower to test it i thought it was bad, on 12v battery and two wires when that thing jumped scares the sh** out of me :) ended up being fuse 48 or 49 (30amp.)
    Siinman Thanks this.
