Blowing coolant out of my blow by tube.
Discussion in 'Ask An Owner Operator' started by Yard Dog64, Apr 3, 2021.
  1. Yard Dog64
    Yard Dog64 Bobtail Member
    Any body ever used liquid head gasket repair, if so did it work and for how long?
  3. bad-luck
    bad-luck Road Train Member
    3,300
    6,066
    Nov 16, 2013
    Baltimore, Maryland
    Never have used it, but if you have a bad head gasket, I would not wast my money on it. Get it done right.
    Vampire, mitmaks, Shawn2130 and 2 others Thank this.
  4. AModelCat
    159,412
    She's toasted. Mechanic in a bottle usually wrecks more stuff in the long run.
    mitmaks, 77fib77, Roberts450 and 3 others Thank this.
  5. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    I still keep a can of stop leak just to get me home ...
    John E Walker Thanks this.
  6. Arctic_fox
    4,090
    21,246
    Sep 16, 2016
    Yea, its literally a "get to the nearest safe place and/or shop" additive. Long term it can damage stuff and may even take a minor failure and turn it into a major one. I keep a bottle in my rig sure. But only as a last resort.
  7. AModelCat
    159,412
    Now on to the obvious fact. Coolant is coming out the blow by pipe. Your oil is finished. Keep running it and you'll be in for a complete rebuild sooner than later.
    Vampire, bzinger, 77fib77 and 2 others Thank this.
  8. John E.
    John E. Light Load Member
    239
    973
    Apr 4, 2021
    New Brunswick
    The O/O's above are correct, fix it right, won't take the pressure under heavy load.
  9. 77fib77
    77fib77 Road Train Member
    10,637
    66,975
    Jul 7, 2010
    St Louis
    How far to get you home? I know some people have dumped their oil once that happened and run straight home good oil. One guy said he did two oil changes to get him self home. The antifreeze eats bearings and sucks in lubrication, so..... It's a dangerous game at this point.
    Vampire Thanks this.
  10. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    When you get the rebuild done after you put a load of stop leak in you will get billed for a new rad. as well.
    Vampire and bzinger Thank this.
  11. snowwy
    snowwy Road Train Member
    20,558
    13,286
    Jul 6, 2009
    And 2 heater cores.
