Blowing out EGR cooler with a leaf blower?
Discussion in 'Volvo Forum' started by Amram, Mar 26, 2019.
  1. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    Could a person theoretically clean the egr cooler by hooking a gas powered leaf blower to the outlet side of the cooler, remove the hot pipe and just blow that soot backwards right out the inlet side of the cooler? Typically on my truck the inlet face of the coolant coils get clogged. So I wonder if this would work.
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Nope it’s stuck there good .. you gotta remember egr is under higher boost than what your blower makes
  4. Amram
    448
    235
    Feb 4, 2017
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Why not just toss the clogged pipe and drop a nice new one in?
  6. Brandt
    Brandt Road Train Member
    4,598
    6,311
    Sep 17, 2012
    Just get the whole system cleaned out
  7. Amram
    448
    235
    Feb 4, 2017
    Wonder how much that costs.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    NAPA used to sell this solvent called hydrozone, for cleaning egr coolers.What this guy does with the egr removed, can be done on the truck, avoid the remove/ instalation hassles , just two hoses at each end, a bucket and a pump to circulate the cleaning liquid through egr cooler. I understand the soot plugging egr cooler is mixed with oil that makes it sticky and this solvents or degreaser dissolve oil. I watched another video, some guys use "Purple Power degreaser " works well, but have to rinse it well after, both this chemicals can chemically break down the motor oil . Power washer should do it also.
  9. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    I am a dealer for Diesel Force. Been providing the service for almost 2 years. It does have an 80% success rate. Other 20% of time is when there is a EGR cooler failure, excessive fuel build up from injector failure or a DOC or SCR that is reached its end of life. Cost is $1200 for process in video. There is now a newer and more powerful machine that is used that works much better.
    little cat 500 and Brandt Thank this.
  10. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Highly suggest diesel force cleaning have had a great success rate with this I did it on about 30 trucks so far and 90% successful even fuel and power will go up most of the time.
    QUALITYTRUCK and magoo68 Thank this.
