Blown fuse 386 Pete, now won't start.
Discussion in 'Peterbilt Forum' started by 82ndCowboy, Jun 20, 2010.
  1. 82ndCowboy
    82ndCowboy Light Load Member
    91
    39
    Nov 9, 2008
    Osteen, FL
    We were installing a caution light to one of the spare rocker witches.
    Accidentally shorted a wire while looking for a hot wire to connect the switch to.
    Replaced the fuse that blew.
    Now the truck will turn over and but will not start.
    we have looked at every fuse we can find, the mega fuses by the batteries, all the ones under the drivers side and the ones up under the sleeper.
    Anyone got any ideas what else to check.
  3. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    what engine? if its cummins look above and to the right of the air compressor, there should be a relay and a fuse, ck those because that controls your fuel pumps. and double check all the fuses, I have over looked 1 more than once. seems like there is another fuse some where, but cant remember where.
  4. 82ndCowboy
    91
    39
    Nov 9, 2008
    Osteen, FL
    Thanks Country,
    We found it. It was in the fuse panel under the driver side.
    The fuse was blown but you had to look at it really close to see it.
    She's back up and running now.
