Blown fuse help
Discussion in 'CB Radio Forum' started by Big Schmidty, Aug 15, 2007.
  1. I'm driving a 2000 Sterling. It has an overhead console that is hard wired for a CB. I touched the pos?neg wires together and lost power. I check the main fuse b ox under the hood and couldn't find a blown fuse. Is there another fuse box someplace else?? Thanks in advance.
  3. BUZZSAW
    BUZZSAW Light Load Member
    176
    15
    Dec 14, 2006
    I am not familiar with the sterlings....touching two wires together is not a good way to find a HOT wire......
    The tractor may have auto reset breakers if so equipped ....after the short is repaired ...the breaker will reset itself. If you checked it immediately after blowing the circuit it will not have any fire in the wire. You may want to seek the help of a more experienced CB tech....
  4. thetez
    thetez Medium Load Member
    380
    24
    Jul 10, 2006
    not a good way to check car battery either.... might have shorted something in the radio...? theirs a few different things it could be..
  5. I accidentally touched the wires together. I got it figured out, is another fuse bank behind a dash panel....replaced the blown fuse and now good to go.
  6. peterbuilt48
    peterbuilt48 Light Load Member
    76
    Jun 11, 2012
    providence,RI
    get your company mechanic to find the hot wire that way you will know its done right.
