Blown tire: how far do you think I can drive?
Discussion in 'Experienced Truckers' Advice' started by jamin22, Jul 8, 2012.
  1. jamin22
    jamin22 Medium Load Member
    301
    256
    Dec 24, 2009
    Blew the recap on the middle axle of a 3 axle trailer. Obviously it's impossible to get it fixed in the middle of a sat.night/sun morning. Load needs to get delivered. Think I can make it 140 miles?
  3. clumben
    clumben Light Load Member
    75
    8
    Aug 21, 2011
    North Dinwiddie, virginia
    Nothing is impossible even in the wekends, there are shops that do road side work and if you work for a company that have some safety they will get on e out to you to change it.
    I blew one tire one day and i did not move until i had a new tire on the trailer and you are thinking about doing 40miles?
    good luck if you take the chance
  4. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    First question is:are you running singles or duals?
    Second question:how heavy is your load.
    Third:do you have a jack?
    Why is it that when people ask something,they never give the full info? :biggrin_25511:
    Roach Thanks this.
  5. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Blew a outside drive tire in Little Rock in front of Maverick's yard and rode all the way to West Memphis at 60mph to get it changed....no problem
  6. jamin22
    301
    256
    Dec 24, 2009
    I figured dual was self explanatory or I wouldn't be running at all obviously. Even if I was a tandem I probably wouldn't risk it. But I'm tri axle. Problem is I'm also 98k and the tire next to it is significantly hotter than the rest
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    You're are allowed to get to the nearest shop if you aren't a hazard. If you're slinging rubber than you probably need road service. I know I always try to make a shop if I can. I've driven up to 60 miles before. It all depends on the scenario.
    It's dark out! :biggrin_25521::biggrin_2559:
  8. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The weight don't sound good. Them other tires have to take up the slack. Where are you at?
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    I think you just answered it yourself.
    It is highly likely that you will blow that tyre.
    Limping to a repairshop is possible but 140 miles.............5% that you make it 95% you don't.
    Keep the remaining tyre as cool as possible.(which isn't easy as the heat generated by the tyre remaining will also be stored in the axle)
    Low speed.
    If you can slide the traileraxles to the back,do so.
    Good luck
    CondoCruiser Thanks this.
  10. jamin22
    301
    256
    Dec 24, 2009
    60 miles from freedom
  11. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    I tried to plead that case to FHP before 10 miles north of the Vero Beach FL T/A.
    He wasn't having it
