Have a Blue Parrot and since I bought my new RAZR phone it doesn't work too well.
Experience loud interference when I press the button to make a call, it sometimes clears up when \i press the volume buttons up or down, but most times \i have to cancel the call and retry. Sometimes it works ... sometimes it doesn't.
Anyone else having compatibility problems, or have any solution???
Blue Parrot and Motorola RAZR
Discussion in 'Cellular - Voice - Data' started by Old Tom, Mar 9, 2012.
I have a Razr and have not had any of the problems your talking about, maybe its the headset??
I'll give Blue Parrot a call on Monday and see if they have any suggestions. -
try re-pairing it again.
If you have another Bluetooth, try it with the Razar to see if it's the phone also.
You've been-----\/\/\/\-----Thunderstruck!!! -
Problem solved!!
Called Blue Parrot Customer Service/Tech. He told me to delete the headset from the phone, then turn the headset on, then press both volume buttons and hold them down until you hear two "beeps". This will clear the headset memory.
Turn the WiFi on the phone to "OFF", then re-pair the headset and phone.
Apparently in some of the newer phones the WiFi conflicts with the pairing of the Bluetooth, and that is what was causing my problem.
Thanks to all for your valuable suggestions.wulfman75 Thanks this.
