Bobtailing with car in tow
Discussion in 'Ask An Owner Operator' started by jyhm, Apr 13, 2010.
  1. jyhm
    jyhm Light Load Member
    126
    12
    Mar 18, 2007
    New England, USA
    Hello O/O's
    I am trying to find the particulars for bob-tailing with an auto in tow. I am in the process of trying to purchase a truck soon from a dealer and I will probably have temp plates and would have to deadhead to my lease company, but I have to bring a car back up north first.
    I am not sure if it is even en legal to do if all you have are temps and bobtail insurance or if it is legal at all.
    I am also unsure of the equipment necessary such as a tow bar or if that would even work.
    Any input from folks that have done this would be appreciated, thanks
  3. Allow Me.
    10,677
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    I've seen it done numerous times. Be sure you have a proper tow bar etc. Get a temp tag from the selling dealer to move the truck legally. In Az. there's no charge.
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    You can get a pintle hook / ball hitch combination that will bolt onto the back of your tractor. The reason I suggest the combo hitch is that it gives you abilities further down the road (ie if you get work with a dirt contractor).
    You may need a gender adapter if you wish to use a u-haul auto dolley or auto trailer for your lights. Some how I dont think u-haul will question if your truck is strong enough for the job. LOL
    is available from Northern Tool for $99
  5. jtrnr1951
    jtrnr1951 Road Train Member
    whatkinda truck ??
    Very easy 2 do
  6. jyhm
    126
    12
    Mar 18, 2007
    New England, USA
    Interesting piece of equipment LovestheDrive,.. how does it interact with the auto? Will I have to purchase another section to attach to my car itself?
    I am not sure what truck yet but probably a VNL670
    Thanks
  7. MeatHead
    MeatHead Medium Load Member
    327
    115
    Sep 25, 2009
    When all is said and done it would probably be cheaper to take a bus or plane instead.
  8. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    here are some visuals since you asked.
    The car dolly allows you to put your front wheel drive axle onto this mini trailer (trailer must be attached to vehicle that is doing the towing). With attached straps you bind your auto to the dolly. If the vehicle is rear wheel drive you will need a trailer to fully put the whole vehicle onto the trailer (pricey).
    jyhm Thanks this.
  9. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    No, if the vehicle is rear wheel drive, like my pickup, you just put the rear of the
    vehicle on the dolly.
    And I know that it can be done as I have towed my pickup many times on a dolly.
  10. sebo
    sebo Medium Load Member
    334
    139
    Aug 13, 2007
    camarillo,ca
    or couldn't just put it in neutral?
  11. phroziac
    phroziac Road Train Member
    3,138
    502
    Jun 16, 2009
    Gary, IN
    Automatic transmissions can be destroyed by doing this, the oil pump cant be turned by the axle. however, you can idle the engine to solve that (expensive). Learned that one time when i got towed by a tow truck.
    They don't reccomend it for stick shifts either. Infact if you get a tractor-trailer towed they disconnect the driveshaft (for $50...).
    or put it on the dolly backwards, but then the only thing holding the wheels straight is the steering lock. On my car, I can break the steering lock with my hands, but it's an import. :)
    You can solve that by looping a belt around the steering wheel and jamming it in the door.....
