Booby trap on a trailer, can you picture the accident?
Discussion in 'Experienced Truckers' Advice' started by iceman32, Feb 1, 2015.
  1. iceman32
    iceman32 Medium Load Member
    564
    699
    Sep 26, 2014
    A friend of mine sent me this picture. I asked him if its loaded, he said yes. I asked with what? He said liquids. I asked if he tapped the area with a rubber mallet. He said yah the frame wobbles and the sound echoes. I said don't take that trailer. He said its a forced dispatch. And I said, drive carefully and take it to the nearest weigh station, tell the dot your hauling death ;D
    http://i1061.photobucket.com/albums/t478/Mistersir1970/Mobile Uploads/image_zps4469b46d.jpg
    Ok for the people that don't get the type of damage. You never ever want to haul a trailer like this. The center point is damaged and is probably broken. The nuts inside are probably misplaced and thats definetly not going to stop a load shift, but the load will bust out. The dented frame wobbling and metal sound echoing means that, that area in the frame is misplaced.
    Same thing with dents on the corners of the bulk head. You have to look at the trailer to see if the top frame is leaning back. If its leaning back, then the bottom bulk head screws are loose. Can you haul a trailer like this? Of course you can, but you'll be surprised when you drive for about 20 miles, look at your mirror and see that your hauling a flat bed instead ;D.
    Vito, DoneYourWay and magoo68 Thank this.
  3. drvrtech77
    drvrtech77 Road Train Member
    14,295
    138,626
    Mar 20, 2010
    Don't haul it at all...
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    It's never a forced dispatch if your pre-trip inspection uncovers safety issues.
  5. iceman32
    564
    699
    Sep 26, 2014
    Imagine if another trucker just hooked to this trailer and didnt do an inspection at all ;D. The load is going to be everywhere when he takes a sharp right curve. It would be much worse if the trailer is loaded with them 7 foot tall paper rolls ;D
  6. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    Forced dispatch doesn't matter when it comes to unsafe equipment. Anything happens he will be held responsible for knowingly using unsafe equipment. Document ever little thing with that trailer, including trailer #, vin #, license plate, BOL or seal #, etc... And take pictures along with all defects and then report it to safety as to why you are refusing unsafe equipment. Any retaliation for refusing to use unsafe equipment, such as penalties/termination, can have legal consequences for the company.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Since when are scratches in the side of a trailer a safety issue? If that was the case, every trailer on the road would be put OOS.
  8. 201
    201 Road Train Member
    12,327
    25,206
    Apr 16, 2014
    high plains colorado
    Hi Bakerman, I hear ya'. I can't tell, is it bowed out or something? I heard, as long as the bottom rail (where the braces are riveted to the rail) on van or reefer are ok, it's not a hazard. Like you say, when I hauled RR trailers, they all looked like that. The load that made me quit RR trailers, ( although, I was going to quit anyway) I was dispatched on a load of peat moss in bags, and the dispatcher said, it might be heavy. When I found the wagon, there were 2 dents on each side on the bottom rails where the crane lifted it off the flat car. I backed under it, and ooph, I could tell right away it was heavy. My drivers axle load gauge said almost 100 lbs. ( 64 lbs was 34,000) I said, screw this, pulled the pin, and bobtailed home, and quit the next day. When I called the company telling them my plate was in the mail, I asked, what ever happened to that load of peat moss. She said, she dispatched it to someone else, and they hauled it.:biggrin_25513:
  9. iceman32
    564
    699
    Sep 26, 2014
    LOL! Look very carefully at the picture, you might need to zoom in. Of course its not the scratch, but the frame is dented in. It means that area, that center point is weak. The nuts and metal pieces that hold the top frame to the bottom frame is damaged.
    wore out Thanks this.
  10. wore out
    wore out Numbered Classic
    15,952
    192,990
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I guess the picture isn't enough for me. I tried to blow it up but still couldn't see but the crease on the wall
    "semi" retired, RunFlat and G.Anthony Thank this.
  11. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    much ado about nothing
    not every trailer is brand new
    drivers like the law as long as it is in their favor
    care nothing about getting it done
    that is the job part
