Boost Wire C15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ozstickman, Mar 23, 2011.
  1. ozstickman
    ozstickman Bobtail Member
    5
    QLD
    Gday from Australia.
    I made myself up a boost wire for my mates C15 but when he plugs it in it shows up high boost pressure on the Cat comp on the dash. Nothing to worry about or should he be concerned? He doesn't have a normal boost gauge on the dash.
    This is on a C15 9NZ motor here in Aus.
  3. ozstickman
    5
    QLD
    heaps of views but no comments......
  4. Diesel Dave
    8,680
    24,659
    Jan 20, 2010
    Hesperia, Ca.
    You have to wait till Mr. Haney reads your thread, He will reply soon as he reads it. He is a very busy man... Be patient mate.
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    I don't quite understand what you're discribing.
    When you install a boost wire the ECM will read it as higher boost. If you turn the key on, but don't start the engine..........the electronic dash read out will show you how much your wire is fooling the ECM with a higher boost reading. It should read 0 psi without the wire. With the wire it shows the extra you're fooling by. You want this to read ion the 7-8 psi range, you can make it read higher or lower by raising or lowering the resistor ohm size. 1000 ohm = 7.0-7.3 psi of boost, 1500 ohm = 10.5-11 psi of boost
    I don't like using more than 1300 ohms, otherwise you'll increase the soot levels in the oil very fast. I will not build a wire for an early single turbo engine above 1300 ohms and try to talk everybody into a 1000 ohms. The Acert engines can get away with a higher resistance resistor without soot levels increasing to dangerous levels between regular oil changes.
    hopefully this asnwers your question
    Cat sdp and t800kwopper Thank this.
  6. ozstickman
    5
    QLD
    most discussions tell me to use a 5k resister. I'll go get some 1k ones and redo it and get him to try it.
    Cheers
    Stickman
  7. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    i had a 1.5 k on mine worked fine but smoked like an old mack
  8. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    I've seen that in threads before..........I just shake my head in wonder............I wonder how the motors survive
  9. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    It works fine, until you start looking at oil analysis and seeing the soot levels high enough to grind up internal engine parts
  10. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    i tryed the 5 k seamed like it cut the fuel around 35 pound boost i don't have any boost wire now just the fuel wire
  11. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    Between the boost wire and the actually boost being produced the engine was derating due to high boost, the ECM doesn't do this unless it's seeing a boost of roughly 60 psi
