Borg Warner Turbo 171702 on a Detroit engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4rdtruck, Jul 27, 2020.
  1. 4rdtruck
    4rdtruck Bobtail Member
    27
    7
    Nov 19, 2014
    Has anyone installed a 171702 Borg Warner turbo on a Series 60 engine 14L. by themselves?
    I know there are some adjustments needed to be made and trying to get more information about it.
  3. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    Have one on mine, you'll need it tuned though to make it run correctly.
  4. 4rdtruck
    27
    7
    Nov 19, 2014
    It's already tuned. I just need to remove the original turbo and install the 171702 one. But I know there are some adjustments needed to be made like oil lines. Do you know the steps for doing that?
  5. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    Is that an EGR 14Litre engine ?
  6. 4rdtruck
    27
    7
    Nov 19, 2014
    Yes.
  7. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    The Drain tube Plate that bolts on turbo is tight but can fit and the Drain tube can be cut and use a Silicone hose or something that takes oil and heat or need to Fab a new drain tube the pressure line Fitting in the VGT turbo is Oring ftting and the BW will have 1/4" NPT Thread Hope that helps you may PM if you wish
    BoxCarKidd and 4rdtruck Thank this.
  8. 4rdtruck
    27
    7
    Nov 19, 2014
    Thank you!
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,476
    6,514
    Aug 26, 2014
    I thank silicone hose is a bad idea for that.
  10. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    What would you suggest instead ?
  11. StrokerTSi
    532
    777
    Aug 28, 2016
    My drain is custom hydraulic line
    BoxCarKidd Thanks this.
