Borg Warner turbo upgrade ??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by areelius, Aug 5, 2015.
  1. areelius
    areelius Light Load Member
    270
    119
    Nov 9, 2012
    Temecula Ca
    I had my ecm tuned 2 years ago by rebel 127 and my engine runs fantastic. He mentioned that it would run even better if I put on a Borg Warner 171702 turbo. Its a 12.7 Detroit . Have any of you Detroit owners put this turbo on? What were the results?
    Thanks very much.
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I wouldn't recommend the 171702 without a tune, but with a tune it's pretty good. It is larger than the stock turbo. Larger means more lag. You want to cruise at 1500+ and when it's hot out it really wont start spooling until around 1350. It will keep your EGTs down and is capable of more max HP.
    Downsides - more lag, less jake performance.
    areelius Thanks this.
  4. areelius
    270
    119
    Nov 9, 2012
    Temecula Ca
    Thanks Alan;
    I have a great tune at approx 500 wheel horsepower. It runs great but Rebel 127 said it was choked down with a "dinosaur turbo" He thought it needed opening up. On Ebay a 17702 is about $650 new. It seems too cheap to me. Maybe it's a Chinese knockoff.
    I have the stock turbo that came on the Detroit 470 horse engine. I could buy the Borg Warner and give it a try. What turbo would you put on this set up? I pull dry van and my gross weight varies from light to heavy. Western states only. I may have to put a DPF on this soon, so that must be factored in also. It won't go over 28 lbs of boost the way it is.
  5. Ruthless
    Ruthless Road Train Member
    8,810
    86,341
    Aug 28, 2010
    The City.
    I have a 171702. And a rebel tune. Down low it is a bit laggy, but she does fine 1450 and up. Get your turbo from a reputable source. Spending less money on the upfront only to have to buy another and clean out the CAC after it pops isn't a good way to go.
    tommymonza Thanks this.
  6. Ruthless
    8,810
    86,341
    Aug 28, 2010
    The City.
    wore out, joey8686 and Cetane+ Thank this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    tune ecm? can somebody explain me what does it mean ? rising the hp ?
  8. mhyn
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    that turbo you saw on ebay is 'made in china' borg warner product. today 95% oem turbo's are manufactured in china. just two day a go took out oem turbo from dd15 engine and the label was showing Holset HX55 made in china. Paccar's turbo is made in china too.
  9. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    It involves adjusting the software to change fuel delivery , injection timing and boost/fuel delivery rates, in addition to pedal sensitivity adjustment.
    Mostly it's used to achieve higher power and better fuel mileage.
  10. mhyn
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    thanks MB3MMX. on Detroit you can do that by using DDCT. and aftermath would be higher thermal load on engine components and fantastic high level of NOx and CO..)))
  11. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Ruthless Do you achieve that much boost on a regular basis? My 12.7 has a tune, a BW 171702 turbo, and a shimmed fuel pump. I would get nervous when the gauge went past 35 and would keep going if I kept my foot into it. The gauge only goes to 35 lbs. but the needle would start a second trip around.
    Bean Jr. and areelius Thank this.
