Bouncing Fuel gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by magellan, May 6, 2016.
  1. magellan
    magellan Light Load Member
    65
    14
    Feb 8, 2016
    I've got a 2012 KW T700, 470k miles currently. What causes the fuel gauge to not regulate? While driving it looks like its having a seizure. While it is showing an 1/8th of a tank I still had close to 120 gallons. What could be the problem?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    One of two things. Lose wire connection or the sending unit is about to give up.
    F1EXPRESS and x1Heavy Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,134
    Mar 5, 2016
    White County, Arkansas
    HM..... that would be it.
    You best get to it. Figures a 300 gallon tank, 150's on each one, 120 stated remaining, 60 per tank. Less than half but above 1/3. Eh... that is not much to slosh the gauge unless you hit a real bad washboard...
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    something could have broke loose in tank, like part of a baffle & is hitting the metal rod with float in tank. mine has been doing that for 15 years.
  6. EZ Money
    EZ Money Road Train Member
    Agree...It is rarely the gauge itself but most likely a bad connection or the sending unit is bad.
    All it does is work on ohm readings from the sending unit..
    F1EXPRESS Thanks this.
  7. magellan
    65
    14
    Feb 8, 2016
    Got it thanks guys. I have been using a stick marked off in sections to aid in the fuel reading until I get it fixed.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Most likely a sending unit. Typically not too difficult to change out.. I've replaced them on T800s, T660s, and T680s... unfortunately, if I ever did one on a T700, I don't remember it. The T680, you can reach it underneath the back of the cab.. pretty simple to swap them out. The T660, we'd have to remove the cab fairings, loosen the tank straps, disconnect the supply and return lines, and rotate the tank (much easier on a near empty tank, suffice to say). I would expect the T700 to be more like the T680 in this regard, but I can't promise it.
    RubyEagle and magellan Thank this.
  9. magellan
    65
    14
    Feb 8, 2016
    I'll take a look tomorrow to see if I can find it and hopefully replace it myself.
  10. colorado18spd
    colorado18spd Medium Load Member
    396
    298
    Mar 10, 2013
    My 09 Columbia did that till I replaced the sending unit.
    F1EXPRESS and The Biggest Dawg Thank this.
  11. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    It's just six screws. Not really a lot to it if you don't have to take off the fairings and rotate the fuel tank. I wish I could tell you definitively which is the case, but I've only ever worked on T700s a couple times (there were a couple in a fleet of primarily T660s, then the T680 became the mainstay of said fleet), and that's one repair I've just never had do on that particular model.
    magellan Thanks this.
